What does "part time" mean in 4wd? - Page 2 - JeepForum.com
post #16 of 26 Old 01-12-2010, 04:02 PM
Jeffro06
Jeffro06's Avatar
Anytime......do you need me to explain that?
Jeffro06 is offline
post #17 of 26 Old 01-12-2010, 04:04 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Who doesn't love this?
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #18 of 26 Old 01-12-2010, 04:10 PM
buickgnx88
U might want to re-think that....
Darn it Max!!
Thanks, that's what I get for replying while watching TV!
Rob99: It can't be a scam. There's pictures of Asian people in business suits pointing at charts and graphs.
Pvt_Joker: One time i had a taco at taco bell, later i got the runs. Therefore, all tacos ever will always make me sit on the toilet for three hours. This concludes my study.
2006sport: You just backpedaled so fast you did the moonwalk.
buickgnx88 is offline
post #19 of 26 Old 01-13-2010, 05:11 AM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
Originally Posted by Mean Max View Post
Or an XJ
Max
my 98 xj only had part time.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #20 of 26 Old 01-13-2010, 08:22 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
The NP242 was offered throughout the XJ production (I think) so I should have worded that better!
Nice catch!
Max
Mean Max is offline
post #21 of 26 Old 12-07-2011, 09:49 AM
SteelPitts
"Part Time" 4wd in 01 TJ
Hello, I've read the explanations about the 4hi and 4lo in my 01 TJ. So, is it okay to use the 4hi on the highway in snowy/icy conditions? What some said about the transfer case "binding" made me question whether highway speeds/conditions would cause damage? I had an 82 CJ that I drove in 4hi at any and all times that the roads were questionable and never had a problem. Thanks.
SteelPitts is offline
post #22 of 26 Old 12-07-2011, 09:50 AM
buickgnx88
I drive my YJ in 4WD hi at speeds around 55-60 when there's snow on the ground and no dry spots. Haven't had any problems yet.
post #23 of 26 Old 12-07-2011, 09:58 AM
danielbuck
1946 CJ2
heh, yea "part time" sounds kind of deceptive, it kind of sounds like it's a watered down 4wd that wouldn't get you out of wet grass.
After reading up on this while looking at jeeps before I had one, I came to think of it more like "fully engaged" and "partially engaged", but reverse from what they are actually called. (even though 'partially engaged' is not accurate?) The terms given to these types of 4wd describe their usage (how often they should be used), not their level of engagement or ability.
Part-time 4wd is "fully engaged", front and rear are fully locked together at the same speeds, meaning you really only want to use it part of the time (the part of the time being only when you are off road), not all the time when you are just driving around town or something. Front and rear will always spin at the same speeds regardless of what the terrain or the rest of the vehicle is doing.
Full time 4wd is "partially engaged", the front and rear aren't always locked together (someone mentioned like an open differential, is this correct?) so you could run it all the time in any road condition. The front and rear will spin at different speeds when needed.
danielbuck is offline
post #24 of 26 Old 12-07-2011, 10:28 AM
Xpress
My Jeep had a part time 4wd system. Part of the time the front axle would drive, the other part time it wouldn't
All about that unibody life.
Xpress is offline
post #25 of 26 Old 12-07-2011, 10:34 AM
ytowntj
Youll be fine on the highway. Its a part time system that functions very similarly to your old CJ. The biggest thing with the bind is that if youre on dry road for very long. A few 100' dry patches in the road when its icy certainly wont hurt, but you cant drive 1/4 mile on pavement and not do a bit of wear
Parting my TJ:
My build - Odd approach to 33's
ytowntj is offline
post #26 of 26 Old 12-07-2011, 06:40 PM
RogueSpear2023
It will be fine, technically even on dry pavement you will be fine as long as you don't turn, or rather sharp turns like on the street, on the highway it will be fine. You will know when binding occurs, I don't use the 4wd until I need it on the streets or highways. You have to be going slower than 55mph to engage or disengage the 4wd, but if you need 4wd you shouldn't be going faster than 55mph anyway. After engaged you can go faster than 55mph though.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
Jeep is "jerking" from time to time when driving down the raod... TJoshX TJ Wrangler Technical Forum 5 07-13-2009 09:06 PM
"Part Time" 4X4? Please Explain... ABwhitetail TJ Wrangler Technical Forum 12 07-04-2008 11:41 AM
"Part time" Light inopp... BumpaD_Z28 TJ Wrangler Technical Forum 15 10-09-2007 04:45 AM
What years have "part-time" 4 wheel drive? coppa TJ Wrangler Technical Forum 25 04-02-2005 12:57 PM
"Part Time" or 4WD??? ScottioTJ TJ Wrangler Technical Forum 19 01-25-2005 10:54 AM
