What does "part time" mean in 4wd? - JeepForum.com
post #1 of 26 Old 01-12-2010, 03:02 PM Thread Starter
woodman1
I just purchased an 01 Wrangler today and was going through it to make sure everything works. When I put it in 4 wheel high or low it says part time on the dash. My 84 Cj didn't have any lights :-) Of course there is no manual with this thing ptherwise I wouldn't have to ask. Thanks for any help.
woodman1 is offline
post #2 of 26 Old 01-12-2010, 03:05 PM
buickgnx88
Part time means it can only not be engaged on dry pavement. I guess they decided to have the 4WD indicator light say part-time, to remind people of the system they are using.
Rob99: It can't be a scam. There's pictures of Asian people in business suits pointing at charts and graphs.
Pvt_Joker: One time i had a taco at taco bell, later i got the runs. Therefore, all tacos ever will always make me sit on the toilet for three hours. This concludes my study.
2006sport: You just backpedaled so fast you did the moonwalk.
buickgnx88 is offline
post #3 of 26 Old 01-12-2010, 03:30 PM Thread Starter
woodman1
I see. I guess I should have searched the subject since i see a few other identical questions. Thanks for not making to much fun of me.
woodman1 is offline
post #4 of 26 Old 01-12-2010, 03:37 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Originally Posted by buickgnx88 View Post
Part time means it can only be engaged on dry pavement. I guess they decided to have the 4WD indicator light say part-time, to remind people of the system they are using.
WRONG!
4HI = PART TIME
I know it sounds like it means it's "partially engaged" but that is not the case. "PART TIME" is descriptive of when you can use it, part of the time.
Part time 4WD units only have the ability to distribute power to the front AND rear. They can only turn the front driveshaft the same as the rear driveshaft. This will cause binding of the driveline, in turn causing damage. That is why it should only be used on loose terrain and/or poor traction environments.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #5 of 26 Old 01-12-2010, 03:40 PM
Jeffro06
Jeffro06's Avatar
U might want to re-think that....
Originally Posted by from the web
Four Wheel Drive Modes
Two-wheel drive (2Hi): In this position, the front axle spins freely while power is sent to the rear axle and wheels, which then drives the vehicle. Part-time four-wheel drive high-range (4 PART TIME): In this position, the centre differential mechanically locks the front and rear driveshafts together, which then rotate at the same speed for maximum traction (this position is designed for temporary use when extra traction is required; only use on slippery or loose surfaces).
Full-time four-wheel drive high-range (4 FULL TIME): In this position, the centre differential splits the power, sending 48 percent to the front axle, and 52 percent to the rear. The transfer case may be left in this position on any road surface - including dry, paved roads.
Darn it Max!!
Jeffro06 is offline
post #6 of 26 Old 01-12-2010, 03:46 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Wranglers only have "PART-TIME" 4WD, some other Jeep models use transfer cases that have both PART-TIME and FULL-TIME capabilities. Here are 2 examples, and there are actually even more than that.
NP231 - "Command-Trac" part-time only - 2.72:1 ratio low range - shift pattern 2H - 4H - N - 4L
NP242 - "Selec-Trac" part-time OR full-time - 2.72:1 ratio low range - shift pattern 2H - 4part-time - 4full-time - N - 4L
Now to explain the difference between part-time and full-time gear selections.
PART TIME
This term describes when this selection should be used, only "part of the time" meaning when available traction is at it's worst & you need the most 4WD capability your Jeep has to offer.
FULL TIME
This term describes when this selection may be used, which is "full time" meaning that you can drive it in this range 24/7 under any traction conditions.
Now to explain how these 2 selections work.
PART TIME
This selection makes a direct mechanical connection between the front & rear driveshafts, and does NOT allow the power to be split at variable rates between the front & rear driveshafts. It operates much the same way a "locked" differential does, with regards to both axles being spun at the same speed. Using this selection on hard surfaces can cause "binding" in the transfer case & thus lead to premature wear and/or damage to the transfer case.
FULL TIME
This selection also makes a mechanical connection between the front & rear driveshafts, but it DOES allow the power to be variably split between the front & rear driveshafts. To make another axle differential comparison, this selection operates much the same way an "open" differential does, with regards to having the ability to direct the power to the 2 axles at different speeds. This allows the use of this selection on any surface & will not "bind" the transfer case.
Max
Mean Max is offline
post #7 of 26 Old 01-12-2010, 03:47 PM Thread Starter
woodman1
I see only 4 choices. 2wd , 4hi , neutral and 4 low. How do I get it in full time?
woodman1 is offline
post #8 of 26 Old 01-12-2010, 03:47 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Originally Posted by Jeffro95 View Post
Darn it Max!!
Oops!
Max
Mean Max is offline
post #9 of 26 Old 01-12-2010, 03:48 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
You don't. Read the first line of post #6
Max
Mean Max is offline
post #10 of 26 Old 01-12-2010, 03:49 PM
Jeffro06
Jeffro06's Avatar
buy a different model.
Jeffro06 is offline
post #11 of 26 Old 01-12-2010, 03:49 PM
TJeeper
TJeeper's Avatar
You buy a Grand Cherokee.
Patrick
TJeeper is offline
post #12 of 26 Old 01-12-2010, 03:51 PM
Jeffro06
Jeffro06's Avatar
Why are you wanting Fulltime? To test your system find a gravel road, put it in 4HI...see if it works.
Jeffro06 is offline
post #13 of 26 Old 01-12-2010, 03:51 PM
JeepDoo
2wd is full time. Meaning you can use it without damage at any time weather on dry pavement or offroad.
My grandpa's 2003 Tj says 4WD when switched into 4 hi or lo. I like this much better than the part time light on my 02.
Hey hey, my my. Rock and roll will never die. - Neil Young
We've got too many gangsters doin dirty deeds. Too much corruption and crime in the street. It's time the long arm of the law put a few more in the ground. Send them all to their maker and he'll settle them down. - Toby Keith & Willie Nelson
Longboard Drunk, Jeep Naked, Ski Powder
and finish calculus homework
JeepDoo is offline
post #14 of 26 Old 01-12-2010, 03:51 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Or an XJ
Max
Mean Max is offline
post #15 of 26 Old 01-12-2010, 03:54 PM Thread Starter
woodman1
Thanks for the quick answers. I get it now.
woodman1 is offline
Jeep is "jerking" from time to time when driving down the raod... TJoshX TJ Wrangler Technical Forum 5 07-13-2009 09:06 PM
"Part Time" 4X4? Please Explain... ABwhitetail TJ Wrangler Technical Forum 12 07-04-2008 11:41 AM
"Part time" Light inopp... BumpaD_Z28 TJ Wrangler Technical Forum 15 10-09-2007 04:45 AM
What years have "part-time" 4 wheel drive? coppa TJ Wrangler Technical Forum 25 04-02-2005 12:57 PM
"Part Time" or 4WD??? ScottioTJ TJ Wrangler Technical Forum 19 01-25-2005 10:54 AM
