What to Do With My Fuel Tank? - JeepForum.com
post #1 of 20 Old 08-10-2013, 12:08 PM Thread Starter
Bigshankhank
My son recently got his drivers license, and while mom and I were out this morning he decided to take the TJ out to buy some things that teenage boys buy. Mom and I, finding ourselves with an empty house decided to take advantage of the situation but were interrupted by a call "Hey I stopped to get gas and now the jeep is running really bad." He managed to limp home after which we determined he put diesel in it. I thought the filler neck was too small, but whatever, he did it anyway. So now that I have dropped the tank and am in the process of pumping it out, I figured it would query JF as to what I can do with my tank on this rare opportunity to have it sitting on the floor.
I am fairly certain I have the 15 gal tank. I can see the "ping pong ball" down in the filler opening, so I am thinking to cut the neck to open it to the full 19 gallons. I am also going to replace the fuel lines and T fitting just as general maintenance.
Anything else I should or could do?
Bigshankhank is offline
post #2 of 20 Old 08-10-2013, 12:48 PM
gunshw301
A good slap on the back of a head for a bone headed move maybe? And why are you doing the work and asking the questions? Get him on here and we can walk him through it!
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #3 of 20 Old 08-10-2013, 01:04 PM Thread Starter
Bigshankhank
Oh he is out there with me mucking up his hands, but now that it is on the floor I figger I may as well do whatever mods are possible.
post #4 of 20 Old 08-10-2013, 01:27 PM
jay-h
At least in NJ we can sue the gas station to have it fixed... but when you pump your own gas, you got no one to blame
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #5 of 20 Old 08-10-2013, 03:12 PM
gunshw301
That's good then. Depending on how bad it is I would look at a sending unit seal.
post #6 of 20 Old 08-10-2013, 11:20 PM
dodgethejeep
Big gasoline only sticker above fuel cap so your son doesn't forget. And new fuel filter
02 tj sold, 90 yj, 08 jku, 03 vf750.
When in doubt dump the mag.
dodgethejeep is offline
post #7 of 20 Old 08-11-2013, 09:12 AM Thread Starter
Bigshankhank
I was wondering about the filter. Again, probably cheap insurance at this point.
post #8 of 20 Old 08-11-2013, 09:19 AM
sjones26573
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #9 of 20 Old 08-11-2013, 09:47 AM Thread Starter
Bigshankhank
I think part of the problem, now that I have visited the particular gas station where this occurred, is that ALL of the pump handles are green, so he just grabbed one and started to it. Oh well, by the time I was his age I had had two at-fault accidents, so I'll give him a pass this time.
post #10 of 20 Old 08-11-2013, 10:31 AM
LimeLJ
LimeLJ's Avatar
Yeah, if pumping diesel into a gas tank is all he has done wrong then things are going right.
The green pump handle thing confused me when I moved from the Northeast to the south. There was a chain of stations up there that used all green handles, but did not sell diesel. Luckily I always read and held the diesel handle for a few moments in confusion.
As for the filter: Some 1997+ fuel pump assemblies have a filter sock on the bottom of it that pop off. Simply washing it out with water or rubbing alcohol will clean it up. Replace it if the plastic mesh is broken.
Definitely do the 19/20 gallon modification! Why not? :P
I do not think your Wrangler is old enough to have one of those big canister inline filters. If you do then replace it.
Do you have an air compressor? The fuel rail at the engine will need to be taken off and blown out along with the fuel line.
2004 Jeep Wrangler Unlimited
1997 Jeep Comanche - 4.7L Stroker, Lifted, "Restored", and soon to be supercharged.
LimeLJ is offline
post #11 of 20 Old 08-11-2013, 11:47 AM
Jonny Jeep
Jonny Jeep's Avatar
The strainers at the base of the fuel pump are only a few dollars. I got mine from rockauto.com. This write up shows how to strip the fuel pump assembly and replace them. The main filter is combined with the fuel pressure regulator on top of the assembly.
DailyDrivenTJ-Fuel Pump Repair
Jonny Jeep is offline
post #12 of 20 Old 08-14-2013, 04:33 AM Thread Starter
Bigshankhank
Well in the end this turned in to a PITA but not a disaster. Sadly, with the TJ being a daily driver I couldn't keep it off the road any longer than it took to get the diesel out of it so despite my ambition, the tank mods will have to wait. I did replace the drain back line and fittings.
For reference, for anyone who didnt already know this, contact the hazardous waste department in your county for disposal of bad fuel. Years back in south Florida I remember the fire department took the stuff and used it now training fires, but apparently not south Texas.
post #13 of 20 Old 08-29-2013, 11:23 AM Thread Starter
Bigshankhank
What gives, the other day I checked this thread and there were four or five other posts in it, now they are gone. No insults, no racial stuff or obscenity, why were those posts deleted?
In response to one poster who doubted that the '00 TJ could take diesel due to the filler neck being to narrow; whether it is or isn't, I still pumped about four gallons out of my tank, maybe yours is different but mine took it like a champ.
post #14 of 20 Old 08-29-2013, 08:05 PM
LMontycj2a
1946 CJ2A
Tell your son he's not the only one who has done this. I know two other people that have done that same thing.
Worst, I also know one person that put gas in a diesel. Bye, bye diesel engine.
As far as the "bad fuel", if you have or know someone with an older vehicle, you know one that doesn't have a computer, just dilute the diesel down with gas and run it through.
1997 TJ Sport, 4.0 I6, 32RH A/T, 31x10.50 General Grabber AT2, totally stock as of now. (need to install the Ballistic diff covers I bought)
1946 Bantum trailer
1946 CJ2A
1968 C-101 (Jeepster)
LMontycj2a is offline
post #15 of 20 Old 05-29-2014, 05:10 PM Thread Starter
Bigshankhank
To bring this back from the dead, my fuel pump just bit the dust on me. Not sure if this contributed, but I cannot imagine that it helped. Lè sigh.
