What is the best year jeep wrangler to get - Page 2 - JeepForum.com
post #16 of 87 Old 05-21-2013, 07:41 PM
Tdog02
Based on what you want to do I would say 98-99. Older keeps the price down and if you are wheeling then resale isn't top priority. I have an 02 TJ and for me its what I wanted for my needs. I daily drive her and had to get an auto trans in case the wife drives. I wheel a couple trips a year for a weekend and about 10 or so day trips.
it is what it is except when its something else
Tdog02 is offline
post #17 of 87 Old 05-21-2013, 09:34 PM
1998tjsport
I have had 4 tjs (1997,1998,1997,2003) so my knowledge is based on those. 1997s are solid and good trucks but a few small things that are unique to them (wiper cowling and ac controls). They are known to have some small issues with the clockspring in the steering wheel as well as the ac controls going a little haywire. 1998-1999 are great and IMO the best early years, and a big plus is that they have the ax15 5-speed which was swapped out in 2000 to the NV3550. The ax-15 is a little cheaper to fix and has less issues from imo. They NVs don't like to shift when they get a ton of miles. 2000 get the NV3550 and coil packs so thats a nice update but the distributor worked fine in all my jeeps so to me its nether a plus or minus. The 2000 and 2001 ones are known to have head warping issues depending on a casting number so that is something to look for. 2002 as far as I know is the same as 2000-01 but without the head issues so they are a solid jeep. In 2003 they updated the interiors and IMO made them much nicer (better seats, gauges, steering wheel, windshield trim, ect). As far as I know 2003 has no issues and the same goes for 2004. In 2005 they swapped to a new computer and a 6 speed both which have proven to be less reliable than the previous years. The 6 speeds are expensive to fix because they are Mercedes sourced and they have similar issues as the NV3550 when they get some mileage on them. The other issue with the 05-06 is the OPDA issues they have because of the new computer. They changed the distributor to convert it to fire the new coils and sometimes they fail and cause camshaft failure, just do a search for jeep tj OPDA failure. That's the basics of them as far as I know, but they are all pretty solid, most issues are nothing major but some things you need to look for.
As far as 2007-2013 go, I believe the early ones (2007-2008) have oil ring issues and they can use oil, however I have never owned one to vouch for this. Also in 2012 some of the early ones had lifter issues I believe.
So basically
TJ-Solid jeeps, not as comfy as the newer ones but they are brick ****houses, I love my TJs.
1997-First model year w/ some unique parts. Watch out for wacky ac controls and airbags lights.
1998-Solid Jeeps, nothing year specific I know of
1999-Same as 1998 no issues I know of
2000-New trans is a downgrade IMO and watch for head issues
2001-Same as 2000 depending on casting number
2002-No issues I know of but if you can afford an 02 IMO an 03 is a much nicer jeep because of the updates
2003-Solid with no specific issues I know of
2004-Same as 2003
2005-6 speed IMO is a downgrade and watch for OPDA failures
2006-Same issues as 2005
Jk- New jeep with lots of good aspects but IMO the 3.8 motors are not to great
2007-Oil issues
2008-Oil issues
2009-No issues I know of
2010-No issues I know of
2011-Updated interior
2012-New motor (improvement over the 3.8) but early ones have lifter issues (covered under warranty)
2013-No issues I know of
WTB INCA GOLD HALF DOORS PM ME
Current-
2003 INCA GOLD TJ Rubicon 5 speed 3inch Currie/Savvy Lift, JKS Discos, 305 KM2s
Build Thread
Past-
1994 Grand Cherokee 5 SPEED 3inch lift, tj bumper, 31x10.5s, wheel spacers, rhino liner, ect.....
1998 TJ Sport 5 Speed 31x10.5s, completely murdered out, and a short throw haha (miss that jeep)
1999 TJ SE 5 Speed (ls swap that became a part-out due to excess frame rot)
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
1998tjsport is offline
post #18 of 87 Old 05-21-2013, 09:37 PM
tyvanwie
Yeah my 08 sucked ******* on the mountain highways
Sent from my iForum using JeepPhone
tyvanwie is offline
post #19 of 87 Old 05-22-2013, 08:25 AM
lynn
lynn's Avatar
Originally Posted by VietVet67 View Post
04-05-06 LJ--your going to want the extra room
Agreed. Still only 2 doors but extra room, better ride, less complicated for a mild lift/33s.
Lynn
'05 LJ
lynn is offline
post #20 of 87 Old 05-23-2013, 12:07 AM
Evian
Mine but you can't have it ;-)
Evian is offline
post #21 of 87 Old 05-23-2013, 08:16 AM
bdub1285
My 01 is very solid. I have around 130k miles on it, and it runs like a top.
I really love my Jeep. I drive it 2 1/2 hours to an offroad park. Then, run black trails all day and drive it home with no issues. TJ's are freaking tanks if you build them right.
2001 Jeep Wrangler Sport, 4.5" lift, Front/Rear ARB Air Lockers, Dana 30/Dana 44 axles with alloy shafts, 4.56 gears, Weld in Roll Cage, 35x12.50 Cooper Discoverer Tires
bdub1285 is offline
post #22 of 87 Old 05-23-2013, 08:27 AM
KickboxingSloth
DONT GET A YJ (heres comes the arguments) get a TJ 97-06 I have an 01 and havent had any problems that wernt my fault
Eat Sleep Jeep Repeat -O|||||||O-
If you aint from Texas you aint ****!!! :)
KickboxingSloth is offline
post #23 of 87 Old 05-23-2013, 01:24 PM
Siva283
Whats wrong with a YJ? My 95 has a fully glavanized frame and tub. Even with salt on the roads I have no rust what so ever. I have 287,xxx miles on it. I daily drive it 123 miles each way to and from work a beat it like it owes me money pretty much every weekend. I replaced the trans at 260,000 miles because we had a hurricane and it got water in it I didnt know about. $100 later and I had another trans for it. I had a broken exhaust valve that punched a hole in the pistion $200 later I had another motor. Including what I paid for it I am still under 5 grand. It will go anywhere I ask it to go. The suspension is simple and easy to work on. Next to no electronics for water or mud to destroy. Blah Blah Blah.
I cant say as much about my problematic 97 TJ I had. Almost every TJ I have seen has rust issues including ones never wheeled.
Ask me how I know...
Siva283 is offline
post #24 of 87 Old 05-23-2013, 01:25 PM
Siva283
In short OP the best Jeep is YOUR Jeep. Best thing to do is test drive them all then pick. You know what you like and want. WE do not.
Siva283 is offline
post #25 of 87 Old 05-23-2013, 01:29 PM
ThatWhiteJeep
The jeep you build and love. That's always the best jeep ever. My 04 may not be factually that great, but she's got a special place in my heart.
Like my GrandPappy said, only way to learn is to do it yourself. Even if you break some things along the way.
ThatWhiteJeep is offline
post #26 of 87 Old 05-23-2013, 10:42 PM
ShogunTJ04
1976 CJ5
Later made 1995 YJ's since apparently some of them had TJ parts put onto them. I have a friend who has a bone-stock 95 that has some cosmetic bits from a TJ if you're into leaf-springs and simplicity. I like my 2004. Doesn't have the OPDA issues, but does have the god-awful 42RLE trans that doesn't know what gear to be in half the time.
That's not death wobble, the roads in PA are just *that* bad.
Stock 4cyl and 35's=Rock Crawling like a bus!
ShogunTJ04 is offline
post #27 of 87 Old 05-23-2013, 10:54 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Originally Posted by Xpress View Post
A 1987-1990 with a 4.2. You will learn.
Fixed it for you !
I am Bias I love YJ's My 95 was issue free for 8 years I regretted selling it so I just picked up another YJ My 98 TJ was a complete turd It was in the shop for warranty repairs 2 1/2 years out of the 3 I owned it ! The best thing DC did was buy it back under the lemon law. I will never have a TJ again after that POS
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #28 of 87 Old 12-06-2013, 05:01 PM
chevy2169
Originally Posted by Anith View Post
How would one come to know if the engine head is cracked? What are the tell-tale signs? I have a 2001 TJ Sport 4 liter here in Italy.
Anith
Well it would be pissing coolant everywhere.
Some say a comet will fall from the sky.
Followed by meteor showers and tidal waves.
Followed by faultlines that cannot sit still.
Followed by millions of dumbfounded dip****s.
chevy2169 is offline
post #29 of 87 Old 12-06-2013, 06:47 PM
AmmitOsiris
AmmitOsiris's Avatar
90 YJ.
Because I Saved 15% On My Car Insurance
AmmitOsiris is offline
post #30 of 87 Old 12-06-2013, 08:47 PM
ThatWhiteJeep
04 TJ with the 44 rear and 5 speed. Love my setup.
