What Axle is this...I thought it was a d30. And should I be worried about this gear? - JeepForum.com
post #1 of 12 Old 08-11-2011, 06:41 PM Thread Starter
nathanninja
So for anyone who ever saw my posts, I'm trying to replace the u joints in the front right of the axle on my 91 YJ. Well I needed a new outer shaft because the ears on mine were bent. So I went to Jeff Daniels, got a YJ d30 shaft. got home, it looks too short. Took it back today, and talked to the guy, we went out back and looked at their axle rack and by process of elimination figured out I have a TJ D30 in the front. Traded axle shafts, all good. Get home, finally get the hub nut off with my new impact wrench (half off, display model ) and after convincing the hub to come off, got the axle shaft out. Well the two aren't quite the same. It's closer than before though. The threading on the end for the hub nut is finer on my shaft, and coarser on the new one. The inner shaft piece (I got the whole thing) is skinnier, and the splines on the end are smaller and more plentiful. The splines on my shaft (I apologize for any innuendos you my draw from my overuse of that word ) are larger and fewer. You can also see the outer piece is a little different. In all these pics, the new (to me) shaft is the one on top, and mine is on bottom.
Finer threads
Larger splines
Okay and now the second part. When I took my shift motor out I noticed that the gear teeth ends looked a little worn, is this anything I should be worried about? And the second pic is of my steering knuckle. The loose bearing cap came around and wore bits off the knuckle as you can see, should I be worried about that?
And lastly a picture of my axle...which I'm 95% sure is a dana 30, but with all thats been going on lately who knows. Also, if anyone could give me a run down of the pros/cons of a TJ d30 over a YJ just so that i know what I'm dealing with, that'd be awesome. If I could get some help here ASAP I would really appreciate it, I wanna hopfully get the new shaft in tomorrow and be driving this weekend
nathanninja is offline
post #2 of 12 Old 08-11-2011, 07:32 PM
1murderedjeep
That is a d30 but I would recommend chromoly one piece shafts if you are going to do any wheeling and I got mine from east-coast gear supply I'm pretty sure they are a vendor on here and you could probably get a deal. Btw I don't believe there is a difference between the tj and yj front axle however the tj has a d35 rear which is known to be weaker.
1murderedjeep is offline
post #3 of 12 Old 08-11-2011, 07:47 PM Thread Starter
nathanninja
I would get the upgraded shafts except I'm dead fricken broke, I got the used shaft for $30 so I got lucky. From what I could tell and what the guy said at Jeff Daniels, the TJ front has a different attachment for the hub and nut. I counted the splines, the new shaft has 27, my old one is 15. I did a little googling, I think he got me a driver's side shaft, I need the passenger with a disconnect. I can take him my shaft tomorrow and have him match it up and hopefully he has a used one for me
post #4 of 12 Old 08-11-2011, 07:55 PM
1murderedjeep
Ya I busted my pass. U joint and shaft the first time I went wheeling. You are lucky to find used shafts I called so many junk yard and couldn't find anything so I have to bit the bullet and get new ones. Good luck and be careful with the seals when you put the new ones in.
post #5 of 12 Old 08-11-2011, 08:00 PM Thread Starter
nathanninja
Thanks man. I priced new ones off morris and qtec and was like crap $100 I'm gonna die, and then I was like what the heck I'll go to the local Jeep shop and see if they've got anything. Those guys are awesome, he gave me both pieces of the shaft for the price of the outer one cuz he didn't want to take it apart. If I ever need something done that I can't do, I'm totally taking the Jeep there. There's only one Junkyard around here with wranglers, and even thats an hour and a half away, and they only have 3 wranglers. On the plus, they have TONS of explorers, 8.8 one day
post #6 of 12 Old 08-11-2011, 08:34 PM
TSEJEEPERS
Like you already found out you have the wrong shaft.
You need the drivers shaft. The only problem is the TJs did not have a axle disconnect.
You can still use a TJ shaft but you will have to install another seal on the inside of the diff.
Plus side is you will have larger U joints.
Not sure of the spline count on the stub axle. Never heard anything about different spline counts.
You may have to change your unit bearings to make it work.
Hey they probably need to be replaced anyway right?
I would also go ahead and change the U joints too. Those looked toasted.
Yes that is a HP Dana 30.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #7 of 12 Old 08-11-2011, 09:48 PM Thread Starter
nathanninja
The drivers side unit bearing seems newer, it looks shiny and spins really well. The passenger side is a little stiffer, but still spins smoothly. The whole reason for me taking the shafts out is to replace the u Joints and passenger outer shaft, so those (nearly immovably stiff) old joints are definitely getting tossed. What does the stock YJ outer (or "stub") shaft look like?
post #8 of 12 Old 08-12-2011, 08:19 PM
TSEJEEPERS
The stub shaft is your second picture.
The stock one is the top shaft.
The bottom one is a TJ shaft with the larger U joint.
post #9 of 12 Old 08-13-2011, 07:14 AM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
I am sure it has been a while since you messed witha YJ 30 but the passanger side is the side with the disconnect on a YJ.
The bottom one is not a TJ shaft, I have never seen a spline set up like that on a TJ shaft before. TJ's are all 27 spline inner and outer in the Dana 30. TJ driver side shafts are interchangable with the YJ inner and outer with no modifications, you will just get a bigger ujoint unless you have a late model 95 Wrangler (driver is the short side). The passanger side (long side) is where you will have to block off the vacuum disco portion and add a new inner seal.
The only difference that would cause you to change unit bearings is to match them up with the correct rotors. All TJ/YJ/XJ/MJ Dana 30 outers will go into any wheel bearing you pull it from. The size of the unit bearing determines the depth of the hat on the rotor.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #10 of 12 Old 08-13-2011, 07:24 AM
BriansCJ
1994 XJ Cherokee
The top shaft is a drivers side regular shaft for a TJ, YJ, XJ, ZJ, MJ...
The botton is the outer shaft of thje passenger side for a disconnect YJ or XJ or MJ. The slide collar uses those huge splines with another internal shaft to lock them together to have 4wd when the t-case is shifted.
All dana 30s from YJs, TJs, XJs, ZJs, and MJs, are the same. Except that some early XJs and all YJs have the disconnect. All other parts will interchange except the ring and pinion from TJs, Late XJs, and ZJs, b/c they are low pinion and XJs, MJs, and YJs are high pinion.
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #11 of 12 Old 08-13-2011, 07:31 AM
jeepinmichguy_
Soar Forever Six
Btw I don't believe there is a difference between the tj and yj front axle.
The difference between a TJ and YJ axle are the YJ uses a vacuum disconnect and has a 2 piece long side inner shaft, plus all YJ D30's are high pinion. YJ's also had smaller 260X ujoints until the 1995 model year when they switched to 297x (which has been replaced by spicers 760X) The hubs and brakes are different but if you match the correct year hubs and rotors they are interchangable. YJ's are set up for leaf springs as well. The TJ uses a 1 piece shaft and all TJ D30's are low pinion. All TJ 30's have 297x ujoints. TJ's of coarse are set up for coils.
ALL YJ's came with a Dana 35 rear except a few Canadian model YJ's that got lucky and came with a D44 (I have never actually seen this, only read it online). Tons of TJ's came with a Dana 44 in the rear. If you want the specifics go read the TJ stock specs in the TJ forum.
ΜΟΛΩΝ ΛΑΒΕ
post #12 of 12 Old 08-13-2011, 11:02 PM
TSEJEEPERS
Oops sorry you are right it was the passenger side.
Rear axle thought. Excuse my ignorance, xj owner here. Jameslol TJ Wrangler Technical Forum 3 08-31-2010 07:03 PM
Found some metal shavings in my new front axle - should I be worried? ChrisTJCO TJ Wrangler Technical Forum 17 07-28-2010 03:32 PM
Axle wrap, something I thought the 2.5 couldnt do YJames90 YJ Wrangler Technical Forum 21 06-02-2010 04:35 PM
I thought I would need a new speedo gear? TJ's02TJ TJ Wrangler Technical Forum 12 01-31-2008 06:48 PM
I thought my axle might have bit the big one..... Stu Olson TJ Wrangler Technical Forum 1 05-23-2006 01:58 PM
