Vinly Wrap Question - Page 2 - JeepForum.com
 5Likes
post #16 of 17 Old 10-06-2016, 11:29 AM
Rusty Scupper
2016 JK Wrangler
There is some mis-information in this thread. The media that is used is a Cast Adhesive Vinyl (no glue needed). There are 3 major players that manufacture this product (3m = 180Cv3, Avery = MPI 1105, Arlon = 6000XRP). All would need a corresponding Cast UV laminate to protect the ink.
The media is printed with either solvent or latex inks. You will need to find a print shop that can create the print file, print, laminate. If it is a repeating pattern then you don't need a template for them to layout design elements to fall in the right place on the vehicle.
Lastly you will need an installer. The installer could be a print shop or someone that just installs. For a clean install you need someone with experience especially on the curved surfaces.
As a rough ballpark you are probably looking at $8-$10 per sq foot for printed and installed. (location, shops involved, media selection, design, etc will all have an impact on that ballpark price).
CNY likes this.
Rusty Scupper is offline
post #17 of 17 Old 10-06-2016, 01:06 PM
xrunndonex
1994 ZJ
I meant to say adhesive promoter around the edges of the body panels. It helps from possible peeling of the vinyl. Po doesn't want to shell out around 3k for a wrap. It's not really that hard once you get the rhythm just takes a bit of time. I've wrapped a few 4 wheelers for some people and they all look just fine to this day.
xrunndonex is offline
