VIAIR install on an 02 TJ w/cruise and 5 spd - JeepForum.com
post #1 of 12 Old 06-10-2012, 08:01 PM Thread Starter
relgnarw
Of all of the searches I've done I couldn't find what I was looking for. I have an 02 TJ and I wanted to mount my compressor under the brake booster on the ABS tray. The problem was that the vapor canistor and the cruise control servo was in the way. Along with the clutch master cylinder resevoir.
First I made a tray out of some 1/4 aluminum plate. Then a made some mounts for the compressor and a manifold from some scrap aluminum. The manifold has provisions for the high pressure relay and an air pressure gauge.
After some test fitting, and some Duplicolor red I was ready to bolt things down. Here is a shot of it dry fitted.
I bolted down the tray using the original bolts.
Next it was time to bolt the manifold down, and bend the lines to the air tank and the regulator. For the lines I used 3/8 brake lines that I got at the local NAPA truck store. I used compression fittings on the manifold, regulator and the air tank.
I bought a regulator at Lowes and used a water separator I had laying around. I made a bracket for the regulator from the same material I used for the tray. Here is one of the lines I bent to go from the manifold to the regulator.
Here you can see everything attached to the manifold.
Then I removed a core support rod bolt and attached the manifold bracket to the support.
"I had wobster at Wed Wobster" - Austin age 5
My onboard air build.
relgnarw is offline
post #2 of 12 Old 06-10-2012, 08:12 PM Thread Starter
relgnarw
Here is a shot from the engine side, you can see the line comming from the compressor to the manifold, then the two solid lines comming out.
This shot shows the regulator line running behind the windshield washer bottle.
Here is a shot of the filtered air for the compressor. It's just a bulkhead fitting to the air cleaner.
Here is the finished deal. I had to raise the cruise control up but it all fits under the closed hood.
The wiring was super easy, I just followed the directions. I used a switch I had bought off of EBAY. I think it looks pretty good
relgnarw is offline
post #3 of 12 Old 06-10-2012, 09:43 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Looks great. Where is the tank?
Luck Favours The Prepared
Anticanman is offline
post #4 of 12 Old 06-11-2012, 03:29 AM Thread Starter
relgnarw
I mounted the tank underneath, next to the frame rail, opposite of the muffler. I'll post pictures later this afternoon.
relgnarw is offline
post #5 of 12 Old 06-11-2012, 11:59 AM
1222
RIP John
1222's Avatar
Very nice clean install and fab work, looks good.
1222 is offline
post #6 of 12 Old 06-11-2012, 05:50 PM Thread Starter
relgnarw
I mounted the air tank underneath, right behind the skidplate. Since I have the UCF belly skid I felt I couldn't use the petcock for the drain.
I may fab a seperate skid for the drain, I don't know.
Here is a shot from the passenger side.
Looking back at the tank you can see the line going in.
Oh and my frame doesn't look this rusty in person.
relgnarw is offline
post #7 of 12 Old 06-11-2012, 06:27 PM
flying_bosun
Looks like an excellent installation. I especially like the tap into the air filter box.
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
post #8 of 12 Old 06-12-2012, 04:37 AM Thread Starter
relgnarw
Thanks, I got the airbox idea from a thread by SKOTT. He did his that way and I liked it.
relgnarw is offline
post #9 of 12 Old 06-13-2012, 10:21 PM
Air Werkz
Very nice installation... it looks great.
PM Us About Our Monthly Specials
[SIGPIC]https://lh3.googleusercontent.com/-04gWo3CF0mQ/UEf-ZkIh0PI/AAAAAAAAApU/MJeWNgrxWQQ/s500/signature.jpg[/SIGPIC]
Air Werkz is offline
post #10 of 12 Old 06-14-2012, 03:49 PM Thread Starter
relgnarw
Thanks, actually I ordered this system from your website. I was impressed with the whole process. From start to finish it took less than a week to get it .
relgnarw is offline
post #11 of 12 Old 06-14-2012, 05:31 PM
Air Werkz
No problem.
Appreciate the business and glad you liked our economy OBA system. You mind if I use these pictures for our website?
post #12 of 12 Old 06-14-2012, 07:00 PM Thread Starter
relgnarw
No problem, feel free.
relgnarw is offline
VIAIR OBA install.....my way oldballz JK Wrangler Technical Forum 50 02-23-2014 05:07 PM
Woods VIAIR OBA Install Dr.Dirty JK Wrangler Technical Forum 12 06-17-2010 07:28 PM
Difficulty To Install Cruise On Non-Cruise Jeep? rastaangel TJ Wrangler Technical Forum 33 05-29-2009 11:00 AM
Viair 450 Install wdstj TJ Wrangler Technical Forum 6 02-06-2006 10:03 AM
450 H Viair install ??'s copeland TJ Wrangler Technical Forum 1 07-01-2003 09:01 AM
