-   Wrangler General Discussion (http://www.jeepforum.com/forum/f176/)
-   -   VIAIR install on an 02 TJ w/cruise and 5 spd (http://www.jeepforum.com/forum/f176/viair-install-02-tj-w-cruise-5-spd-1379665/)
relgnarw 06-10-2012 07:01 PM
10 Attachment(s)
Of all of the searches I've done I couldn't find what I was looking for. I have an 02 TJ and I wanted to mount my compressor under the brake booster on the ABS tray. The problem was that the vapor canistor and the cruise control servo was in the way. Along with the clutch master cylinder resevoir.
Attachment 412920
Attachment 412921
First I made a tray out of some 1/4 aluminum plate. Then a made some mounts for the compressor and a manifold from some scrap aluminum. The manifold has provisions for the high pressure relay and an air pressure gauge.
Attachment 412924
Attachment 412925
After some test fitting, and some Duplicolor red I was ready to bolt things down. Here is a shot of it dry fitted.
Attachment 412932
I bolted down the tray using the original bolts.
Attachment 412933
Next it was time to bolt the manifold down, and bend the lines to the air tank and the regulator. For the lines I used 3/8 brake lines that I got at the local NAPA truck store. I used compression fittings on the manifold, regulator and the air tank.
Attachment 412938
I bought a regulator at Lowes and used a water separator I had laying around. I made a bracket for the regulator from the same material I used for the tray. Here is one of the lines I bent to go from the manifold to the regulator.
Attachment 412939
Here you can see everything attached to the manifold.
Attachment 412943
Then I removed a core support rod bolt and attached the manifold bracket to the support.
Attachment 412945
relgnarw 06-10-2012 07:12 PM
5 Attachment(s)
Here is a shot from the engine side, you can see the line comming from the compressor to the manifold, then the two solid lines comming out.
Attachment 412948
This shot shows the regulator line running behind the windshield washer bottle.
Attachment 412949
Here is a shot of the filtered air for the compressor. It's just a bulkhead fitting to the air cleaner.
Attachment 412950
Here is the finished deal. I had to raise the cruise control up but it all fits under the closed hood.
Attachment 412952
The wiring was super easy, I just followed the directions. I used a switch I had bought off of EBAY. I think it looks pretty good
Attachment 412968
Anticanman 06-10-2012 08:43 PM
Looks great. Where is the tank?
relgnarw 06-11-2012 02:29 AM
I mounted the tank underneath, next to the frame rail, opposite of the muffler. I'll post pictures later this afternoon.
1222 06-11-2012 10:59 AM
Very nice clean install and fab work, looks good.:thumbsup:
:cheers2:
relgnarw 06-11-2012 04:50 PM
4 Attachment(s)
I mounted the air tank underneath, right behind the skidplate. Since I have the UCF belly skid I felt I couldn't use the petcock for the drain.
Attachment 413526
Attachment 413527
I may fab a seperate skid for the drain, I don't know.
Here is a shot from the passenger side.
Attachment 413528
Looking back at the tank you can see the line going in.
Attachment 413529
Oh and my frame doesn't look this rusty in person.
flying_bosun 06-11-2012 05:27 PM
Looks like an excellent installation. :thumbsup: I especially like the tap into the air filter box.
relgnarw 06-12-2012 03:37 AM
Thanks, I got the airbox idea from a thread by SKOTT. He did his that way and I liked it.
Air Werkz 06-13-2012 09:21 PM
Very nice installation... it looks great.
relgnarw 06-14-2012 02:49 PM
Thanks, actually I ordered this system from your website. I was impressed with the whole process. From start to finish it took less than a week to get it :thumbsup:.
Air Werkz 06-14-2012 04:31 PM
No problem.
Appreciate the business and glad you liked our economy OBA system.:cheers2: You mind if I use these pictures for our website?
relgnarw 06-14-2012 06:00 PM
No problem, feel free.
The time now is 07:35 AM.
