Vented Or Non Vented Gas Cap - JeepForum.com
post #1 of 5 Old 06-22-2008, 12:46 PM Thread Starter
joho
On An 89 Should I Use A Vent Or Non Vented Gas Cap?????????????
joho is offline
post #2 of 5 Old 06-22-2008, 01:11 PM
tazzzdvil
1987 YJ Wrangler
I may be wrong, but it'd depend on if your FI or carbed. With injectors, it's a sealed system that needs the balance from a vented lid.
Carbs using a mechanical fuel pump, can you say you have a straw sucking from the bottom of the tank
tazzzdvil is offline
post #3 of 5 Old 06-22-2008, 06:13 PM Thread Starter
joho
it has a carb if this helps
joho is offline
post #4 of 5 Old 06-22-2008, 06:28 PM
tazzzdvil
1987 YJ Wrangler
non-vented. it get's it vent from the hoses I'm in the process of replacing.
post #5 of 5 Old 06-22-2008, 06:33 PM
Luckyduck
So if i put a non vented on my xj (ya I know wrong forum but this is easy then starting a thread) it is a 98 4.0 I put a non vented fuel cap I got out of a TJ in the junk yard. is this bad?
If I can get there I can wheel it!
CentralMass4wd.com
1993 Ranger 2wd - dd
1999 wranger 2.5 - it gets used for something
1978 international scout - being built
1998 Cherokee sport 4.0 auto
1957 CJ5 - restoring back to stock
Bikes:2000 Ducati Monster 900: 2001 CBR 600 F4i: 1980 CB 900
my build
Luckyduck is offline
Vented Gas Cap VS Non Vented CarRamRod TJ Wrangler Technical Forum 7 10-28-2016 06:07 AM
Cat air cleaner vented through cowl bigredcherokee YJ Wrangler Technical Forum 1 05-28-2009 08:34 AM
Gas Cap Vented Or Non_vented ????? joho YJ Wrangler Technical Forum 7 06-23-2008 12:14 PM
gas cap vented or non vented? OlllllllO Jeep1 YJ Wrangler Technical Forum 0 09-04-2005 05:28 PM
Vented or not vented? davebelair TJ Wrangler Technical Forum 2 12-24-2004 04:39 PM
