Transmission Gauge Leaking, Solution?? - Page 2 - JeepForum.com
post #16 of 31 Old 07-03-2013, 05:56 PM Thread Starter
catnip15
Originally Posted by JBTJ
With my experience with compression fittings, used on AC systems. All you need to do is tighten it up. Put 2 wrenches on it and go for it. It won't take that much more umph to seal it up.
The lines are fine, it's the sender unit itself
My Build Thread
http://www.jeepforum.com/forum/f22/stubby-02-tj-build-thread-dd-2523578/
catnip15 is offline
post #17 of 31 Old 07-03-2013, 06:04 PM
JBTJ
Then order another sending unit and be done with it. But your pic with the arrow pointed to it says the fitting is not tight enough.
JBTJ is offline
post #18 of 31 Old 07-03-2013, 06:38 PM
JBTJ
To fix your problem, either try and tighten up the fitting more. Or, unscrew it and add a wrap or two of Teflon tape to the threads and retighten.
JBTJ is offline
post #19 of 31 Old 07-05-2013, 08:15 AM Thread Starter
catnip15
Well I ended up plugging the hole, ended up stopping the leak. Added some tranny fluid to it but I added a bit more than I should have, what's a good way to get some out without dropping the pan. There's enough extra in there that it probably isn't safe to keep in there.
Just one problem after another
My Build Thread
catnip15 is offline
post #20 of 31 Old 07-05-2013, 08:55 AM
JBTJ
Why not just unplug the hole and allow just enough ATF to come back out?
JBTJ is offline
post #21 of 31 Old 07-05-2013, 09:07 AM Thread Starter
catnip15
Why not just unplug the hole and allow just enough ATF to come out?
I guess I could I thought of that but I just don't want to risk making it leak again that was a horrible nightmare
My Build Thread
catnip15 is offline
post #22 of 31 Old 07-05-2013, 09:16 AM
JBTJ
I wish I could understand your problem. I have that exact same setup on mine. No leaks. Though I did have to make sure the compression fittings were really tight and I used 1 wrap of Teflon tape around the threads on the sending unit.
JBTJ is offline
post #23 of 31 Old 07-05-2013, 09:51 AM Thread Starter
catnip15
It's hard to explain lol basically the sending unit is attached to that thin metal hose line with the fluid in it that warms up. When I go to turn the sending unit threads into the T fitting, it is snug (and wrapped in Teflon). The problem is, the thin metal line can be pushed up or down in the unit itself. When this happens, it creates an opening causing a leak.
My Build Thread
catnip15 is offline
post #24 of 31 Old 07-05-2013, 10:02 AM
JBTJ
And that line is a compression fitting? On mine the sending unit screws into the T fitting and the electrical connection is made at the end. Nothing moves. You got the B&M kit?
JBTJ is offline
post #25 of 31 Old 07-05-2013, 10:04 AM
JBTJ
On your last pic of your first post, what is under the black wire loom? Where does it go?
JBTJ is offline
post #26 of 31 Old 07-05-2013, 10:06 AM Thread Starter
catnip15
No it is not, simply screws in. I have a sunpro mechanical gauge. I had a B&M, but it only lasted a year ended up being defective. I just have bad luck with gauges lol
My Build Thread
catnip15 is offline
post #27 of 31 Old 07-05-2013, 10:11 AM
JBTJ
Well if it isn't compression, then it's a flare fitting and the flare is not big enough to seal the line. That or it is a mixed match, meaning the line is a flare fitting going into a "T" fitting for compression fittings.
JBTJ is offline
post #28 of 31 Old 07-05-2013, 10:16 AM
JBTJ
Was this a kit for transmissions or was it something you pieced together?
JBTJ is offline
post #29 of 31 Old 07-05-2013, 10:21 AM Thread Starter
catnip15
It is a oil temperature gauge, same concept though. It wasn't specifically labeled Trans temp but regardless it didnt leak for over a month. Didnt start until after my wheeling trip
My Build Thread
catnip15 is offline
post #30 of 31 Old 07-05-2013, 10:26 AM Thread Starter
catnip15
Sunpro CP8207 Mechanical Water/Oil Temperature Styleline Gauge - White Dial
http://amzn.com/B00029K018
My Build Thread
catnip15 is offline
