Tranny Fluid Change - JeepForum.com
post #1 of 1 Old 05-05-2009, 10:25 PM Thread Starter
EricYoung
Tranny Fluid Change
I have been told several different things. can you put 10w-30 motor oil in when changing the trany. I bought some penzoil sincromesh because of some grinding problems that i have. Is that what i should fill my transmission fluid with? and can i change my transfercase fluid with the same penzoil sincomesh?
Thanks for your replies
95" Sahara Yj
EricYoung is offline
Need to change tranny fluid in my ax-15 soon any tips? fluid to use? Mitchin TJ Wrangler Technical Forum 37 07-04-2010 02:06 PM
Tranny fluid Change BadAddetude YJ Wrangler Technical Forum 7 05-27-2007 01:32 PM
What do you guys use to change the tranny fluid and xfer case fluid?? Wheelman TJ Wrangler Technical Forum 11 12-15-2004 04:33 PM
Tranny Fluid Change JSBlu974X4 TJ Wrangler Technical Forum 2 08-08-2004 02:57 PM
Tranny fluid change help!! Marinerider TJ Wrangler Technical Forum 8 06-28-2004 12:10 PM
