-   Wrangler General Discussion (http://www.jeepforum.com/forum/f176/)
-   -   Tips n' Tricks: Removing Your Wrangler Doors - Avoid Seized/Stuck Door Pins (http://www.jeepforum.com/forum/f176/tips-n-tricks-removing-your-wrangler-doors-avoid-seized-stuck-door-pins-1528393/)
TrailRated2011 05-26-2013 07:54 AM
1 Attachment(s)
Permatex® Anti-Seize Lubricant assures easier disassembly.
SteveBad 05-26-2013 09:29 AM
I have found that it helps to have the door at a 90-degree angle to the centerline of the Jeep when going on or off.
It also helps to have help.
On the TJ, Chrysler made one pin longer than the other, so the whole process was a lot easier. :) When they designed the JK, I reckon the bean counters determined that they could save .5 cents per unit by eliminating that small detail. Rat Bas2766s! :mad:
222Doc 05-26-2013 10:53 PM
I found that is best to remove them. Then leave them off, for good. Heck mine are getting to be like the rest of stuff i removed from this Jeep. soon I may have two Jeeps at this rate one day. My 66 never had real doors any way. Just soft doors. I got soft doors for my Rubi now and no need for hard doors and all the fuss to remove those heavy a$$ things all the time. The soft doors that can be half doors are very nice.
TJDaveX 05-27-2013 07:22 AM
My method:
Whatever is in my grease gun. Smear a dab on each pin when I put the full doors on every fall.
Each spring, the doors come right off. Total cost for 7 years of door removals..$0.00
trav1s76 06-25-2013 07:29 PM
Just found a new method that worked pretty good. I had a set of the forearm forklifts and tried one on my stuck doors. It allows you to get a lot more leverage when you are twisting and lifting upward at the same time. Not saying to go out and buy a set but if you have em its worth a shot. Also makes it easy to carry em around.
bogleparsons 06-26-2013 07:45 AM
Graphite would work great too.
cyberpyrot 06-26-2013 09:43 AM
My Method was to buy Mopar half doors and be done with it :D
mike_dippert 06-26-2013 10:14 AM
Derlin hinge bushings. No rust, no grease mess.
Loadsmasher 06-27-2013 06:58 AM
I concur. Did mine a few weeks ago and couldn't be happier. I put a little grease on the pins just for rust protection.
lumpster 07-03-2013 05:54 PM
I prefer the Delrin door bushings too, if you factory bushings are in good shape use a little grease or anti seize to prolong the life of the factory bushing and keep your door pins from rusting
The time now is 06:56 PM.
