Temp Wheel Help (pic) - JeepForum.com
post #1 of 7 Old 07-04-2013, 12:17 PM Thread Starter
NIUPonyBoy
NIUPonyBoy's Avatar
Should I plastidip the center caps?
I had originally but it got all kinda if crappy when I torqued down the lugs (popped like a sticker). I liked the look but got several compliments on them they way are.
Now I'm a little torn lol
Thoughts?
'15 Expedition EL, '12 Outback,'07 JK, '06 Mustang GT, '05 PowerWagon,'05 Freestar, '02 Yamaha
NIUPonyBoy is offline
post #2 of 7 Old 07-04-2013, 08:31 PM Thread Starter
NIUPonyBoy
NIUPonyBoy's Avatar
Why move? It's a JK. lol
post #3 of 7 Old 07-05-2013, 06:29 AM
JBTJ
Because it's not tech related.!!! Plasti dip is useless for that application.
JBTJ is offline
post #4 of 7 Old 07-05-2013, 08:11 AM Thread Starter
NIUPonyBoy
NIUPonyBoy's Avatar
There is lots of fluff in there still. Lol
And how is it not, it's temp which is the point. I've also seen several people that have done it already, already did the steel portion not sure why the plastic part didn't take it.
post #5 of 7 Old 07-05-2013, 09:02 AM
JBTJ
Depends on the surface of the material your are spraying. Did you scuff up the metal so that the plasti dip has something to hang onto? If you have a surface that is polished with a hard material like your chrome wheels, nothing will stick to it very long. Also, why do it even if it is temporary?
JBTJ is offline
post #6 of 7 Old 07-05-2013, 09:38 AM Thread Starter
NIUPonyBoy
NIUPonyBoy's Avatar
The steel was no problem the plastic was. I am scuffing it today and respraying.
This is just temp until I can get real wheels and new rubber. IMHO the stock steelies are horrid.
post #7 of 7 Old 07-05-2013, 12:41 PM Thread Starter
NIUPonyBoy
NIUPonyBoy's Avatar
Half of them done, again.
I scuffed up the plastic and put down a base of black wheel spray paint and then sprayed over the dry paint with the PD so it is was an even color. Then after it all dried I took the dremel to the holes and cleaned out the "overspray" and then remounted. Went on without a hitch.
Looks so much better IMHO and I don't like black wheels but for a temp solution I like it. Until I can afford to do it right.
