Switchbacks - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > Wrangler General Discussion > Switchbacks
TJ 5.25" Speaker Adapters - NalinMFGTJ, YJ & LJ Drop Down Tail Gate Conversion KitLJ Suspension Systems from Clayton Off Road
Unread 07-07-2014, 01:08 PM   #1
63beetle
Switchbacks
I'm torn between a new wrangler or the unlimited. The unlimited is much more practical for carrying camping gear for 3 people but can it make the switchbacks on trails in Colorado ( like Black Bear for an example)? If we went with the 2 door, I've thought about a Space Trailer to haul gear to the campsite. Thanks.
63beetle is offline   Reply With Quote
Unread 07-07-2014, 01:28 PM   #2
TAE73
You can make it with a 4dr fine, just may require several back and fourths to make the turn.
TAE73 is offline   Reply With Quote
Unread 07-07-2014, 01:31 PM   #3
jwmbishop
2011 JK Wrangler
A two door with trailer seems would be harder than a four door without.
Yes the longer wheel base adds to the turning radius. About 9" to the total radius I believe. I find that by driving into a turn a bit deeper (go straight longer) and turning a bit harder it does make even the toughest of tight canyon turns. And if the turn is REAL tight (a two barely makes it) drive straight THROUGH the turn, steer opposite and back up about a foot - then make the turn. For example a hard left - go THROUGH the turn, steer right - back a foot and steer left and go. Harder with a trailer so if in a turn that even would choke a two door - you can get hung real easy.
A few back and turn? I've never needed more than one to turn just as tight as two door! And LOVE the extra room...
J Wm Bishop EA, ASADE
When I said that I was acceptably sane I may have exaggerated slightly.
jwmbishop is offline   Reply With Quote
Unread 07-07-2014, 01:41 PM   #4
D700
Junior Member
D700's Avatar
2014 JK Wrangler
I just traded my 2 door for a JKU Rubicon. I can get all my gear in and have plenty of space left.
Good luck with your decision
D700 is offline   Reply With Quote
Unread 07-07-2014, 03:19 PM   #5
Dynomax_Exhaust
Exhaust Experts!
I've done Black Bear in a 4 door in 2WD low rear.... no issues.
Well I guess having a broken front axle was an issue.
Follow us on Facebook!
https://www.facebook.com/dynomaxexhaust
http://www.jeepforum.com/forum/signaturepics/sigpic302199_7.gif
Dynomax_Exhaust is offline   Reply With Quote
Unread 07-08-2014, 11:46 AM   #6
bobjp
I did Black Bear in my Jeep with some 4 doors, and they did a lot more backing up than I. I could just swing around the switch backs. It really wasn't that big of a deal though.
97 TJ sport.
bobjp is online now   Reply With Quote
