Are suspension lifts THAT bad? - JeepForum.com
post #1 of 34 Old 01-28-2014, 11:44 PM Thread Starter
zpayne08
So I've been doing research after gettin my 2013 jk that already has a small leveling kit and 33s about putting a real lift kit on. Already know what I want and this has caused my bud to get the bug for a jeep. He was tellin me that you don't need a lift and that when he owned a military CUCV an went off road he never got in a situation that he needed a lift. Only thing he said was needed was good near stock tires, bumpers, and recovery gear. Said lifts throw everything out of spec and weakens everything causing things to break/wear early and that regearing weakens the diffs.
My reply was that as long as you didn't go stupid and did everything right (track bars, control arms, etc etc) and bought from a trusted company that there shouldn't be issues. So what say yee?
zpayne08 is offline
post #2 of 34 Old 01-29-2014, 01:08 AM
Marauder_Pilot
Marauder_Pilot's Avatar
Everything he's told you is wrong on some level.
Yes, lifting over a certain point does stress factory components, if they're not addressed as well. But if you account for everything affected, it evens out.
And how would regearing weaken the diff? It's literally putting in different gears.
"Buying a Jeep for on-road handling is like downloading porn to savor the cinematography."
-TTAC
2000 Jeep Wrangler TJ Sport-OME HD Lift, ProComp bumper, 32" BFG TA K/Os
2010 Kawasaki KLR650-Stock
2006 Ford F-250-Stock
Marauder_Pilot is offline
post #3 of 34 Old 01-29-2014, 01:31 AM
Xpress
Sounds like he has his head up his ***...
All about that unibody life.
Xpress is offline
post #4 of 34 Old 01-29-2014, 06:54 AM Thread Starter
zpayne08
Yea lol. Then after telling me lifts were stupid he wants to drop in a 5.3 Chevy motor
zpayne08 is offline
post #5 of 34 Old 01-29-2014, 09:18 AM
Imped
Imped's Avatar
Knowledge is everything. Unless you're well-educated on suspension (not that difficult to achieve) then you shouldn't be saying things. Your friend doesn't know what he's talking about but he has a point--there are right ways to do things and wrong ways.
Learn then execute.
OlllllllO
IndyORV
Imped is offline
post #6 of 34 Old 01-29-2014, 10:09 AM
bogleparsons
Maybe he means large tires are bad on stock components....?
Or maybe he means deeper gears like 5:38's are weaker because of the tiny pinion.
Or maybe he's b lowing smoke up your arse.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #7 of 34 Old 01-29-2014, 11:49 AM
Eckoh
Just remember Duck tape cannot fix stupid, but it does a really good job at muffling the sound.
Eckoh is offline
post #8 of 34 Old 01-29-2014, 06:56 PM Thread Starter
zpayne08
Lol. He mean lifts period were bad. He thinks he knows everything about cars bc he grew up with a gear head as a father and they always worked on cars. I told him I'd like to go 4.10s with lockers and he made the statement of going higher (numerically) they are weaker
zpayne08 is offline
post #9 of 34 Old 01-29-2014, 07:08 PM
Demp
Bold for emphasis.
A cheap lift slapped on just to fit the tires? sure it might cause some problems
Huge tires on lighter axles? yet again.....
Your friend is going on hearsay from people who don't know how to do things correctly. For example: how often did you hear about control arms, caster, and toe when you were in high school and guys were lifting their trucks? I sure didn't
Regearing only weakens a differential if you do it wrong. I wonder why the Rubicon comes with 4.10 gears if they are weaker? :P
Demp is offline
post #10 of 34 Old 01-29-2014, 08:50 PM
bgredjeep
1987 YJ Wrangler
Fire road wheeler? He never went where I take mine.
bgredjeep is offline
post #11 of 34 Old 01-29-2014, 10:00 PM Thread Starter
zpayne08
I knew he was full of it. Just wanted thoughts. Even though I'm doing a 2.5" coil lift I'm getting all 8 arms, both trackbars, new correct sized bolts, and the exhaust spacers. Buy once cry once
zpayne08 is offline
post #12 of 34 Old 02-02-2014, 01:01 PM
PhulesAu
You are awarded 2 interwebnets points!!!
PhulesAu is offline
post #13 of 34 Old 02-02-2014, 09:25 PM
frenchy206
If done correctly, a lift is just as strong, if not stronger than factory. However, a lift is not the most important part as far as off road capability.
Recovery gear and armor come first, as far as I'm concerned.
Any lift will, obviously, raise you center of gravity, making the likelihood for a pucker moment to happen easier.
03 TJ Rubicon
frenchy206 is offline
post #14 of 34 Old 04-17-2014, 11:39 PM
ancientspear
Kentucky has some nasty red clay mud doesn't it... when he is up to his frame rails in mud (same goes for sand and deep packed down snow) with no momentum AND wheelspin from his 5.3 transplant he will wish he spent less money and lifted the thing and/or invested in tires with more flotation (wider) because all the HP in the world won't help unless it's soft mud/sand/snow where he can throw lockers on when it is too late and dig straight down into more trouble. Hey... this applies to river silt too. Oh what about water crossings, or climbing over logs and rocks... clearance is king and this is from someone who doesn't want to lift... there's a lot of advantages to having it.
ancientspear is offline
post #15 of 34 Old 04-18-2014, 11:21 AM
Astennis1
Sounds like his "expertise" is in on road vehicles. A correctly geared correctly lifted Jeep with a 4 cyl will do more than a 5.3 with nothing else done right anyday. Most wheelers can get a lot of **** done with a 4.0/3.8/3.6 L motor with correct suspension
I LOVE LAMP
13 JKUR
Astennis1 is offline
bad , kit , lift , suspension
