Starting Out With a Load in 1st Gear - Manual vs. Auto - JeepForum.com
post #1 of 17 Old 12-28-2011, 10:39 AM Thread Starter
jrwdlw
I'm looking at buying a 2005 or 2006 Unlimited with a 4.0. I will be towing a 2000-2500 lb folding trailer. I'm trying to decide the manual vs. auto trans issue. I love manual transmissions, but I'm wondering if the auto would be a better choice. I test drove a manual the other day. Of course, I loved it, but I'm wondering how it will be when you try to get 2500 lbs (or more) moving in first gear. I know it can be done, but I'm not sure how "clutch friendly" the process will be. Every manual transmission that I have used to tow (7-10K loads!) had a compound low of about 6.5:1. The 6sp has a 4.46:1 first, but that's a long way from 6.5:1. Unfortunately, I don't know anyone with a manual trans Jeep that I could "test".
So, I would appreciate any comments or personal experiences.
Thanks,
John
jrwdlw is offline
post #2 of 17 Old 12-28-2011, 10:42 AM
giggityjeeper
Originally Posted by jrwdlw View Post
I'm looking at buying a 2005 or 2006 Unlimited with a 4.0. I will be towing a 2000-2500 lb folding trailer. I'm trying to decide the manual vs. auto trans issue. I love manual transmissions, but I'm wondering if the auto would be a better choice. I test drove a manual the other day. Of course, I loved it, but I'm wondering how it will be when you try to get 2500 lbs (or more) moving in first gear. I know it can be done, but I'm not sure how "clutch friendly" the process will be. Every manual transmission that I have used to tow (7-10K loads!) had a compound low of about 6.5:1. The 6sp has a 4.46:1 first, but that's a long way from 6.5:1. Unfortunately, I don't know anyone with a manual trans Jeep that I could "test". So, I would appreciate any comments or personal experiences.
Thanks,
John
maybe the guy who your buying it off of...... just saying..... mostly it would come down to how well you can drive a manual I guess
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #3 of 17 Old 12-28-2011, 12:37 PM
JohnnyWhitehead
2011 JK Wrangler
I have an 05 manual and I tow my 13ft trailer with two ATVs on it with no problems. Take off is fine, it is the stopping that is greatly increased. So you should be good. If you like the manual, get the manual. I love mine.
JohnnyWhitehead is offline
post #4 of 17 Old 12-28-2011, 01:35 PM
LJameson
The NSG370 has a very low first gear, so that helps.
If you get an auto, invest in a good cooler.
1990 YJ
LJameson is offline
post #5 of 17 Old 12-28-2011, 01:44 PM
Marauder_Pilot
Marauder_Pilot's Avatar
I've towed a fair bit with my Jeep (Including a few trips with a 3000+-pound trailer), and while I've only got the NV3550, it tows very nicely on stock gearing, I barely noticed the trailer on acceleration (Braking was another story...), and, since the NSG370 has a lower first gear, I can imagine that it'll tow as well or better.
However, I will note that towing with a lower-than-stock gear ratio BLOWS. Take-off isn't too bad still, because Wranglers have such a low first gear, but highway acceleration...well, you just don't have any. If you lift and put on larger tires, make sure you regear appropriately. Even towing a small unloaded cargo trailer tanked my acceleration.
And, if you plan on doing any regular towing with it, cough up $800 and invest in a Vanco Big Brake kit (Or similar). It's not a huge deal if you only tow once or twice a year for short distances, but if you're towing on any measurable basis, the loss of braking is, honestly, downright dangerous.
"Buying a Jeep for on-road handling is like downloading porn to savor the cinematography."
-TTAC
2000 Jeep Wrangler TJ Sport-OME HD Lift, ProComp bumper, 32" BFG TA K/Os
2010 Kawasaki KLR650-Stock
2006 Ford F-250-Stock
Marauder_Pilot is offline
post #6 of 17 Old 12-28-2011, 02:21 PM Thread Starter
jrwdlw
What do you estimate your trailer and ATVs weigh? Also, what's your axle ratio? The LJs I'm looking at are 3.37 axles.
jrwdlw is offline
post #7 of 17 Old 12-28-2011, 02:38 PM Thread Starter
jrwdlw
From specs, I see that your 1st gear is 4.01. Probably can't tell any difference between that, and the 4.46 in the NSG370. I'm sticking with stock tires, so I shouldn't need a re-gear. The trailer I'll be towing has electric brakes, so that should take care of the stopping problem.
My biggest concern is getting the load moving without having to be absolutely perfect with the gas/brake/clutch (the slightest error in timing, and you stall it). I'm in a major metropolitan area, so getting out to the sticks for some off-roading means lots of stop and go traffic along the way.
LJameson:
Definitely. If I go auto, the first thing happening is a trans cooler!
jrwdlw is offline
post #8 of 17 Old 12-28-2011, 02:42 PM
keithert
keithert's Avatar
I tow the same setup with an automatic. It pulls fine but stopping is much slower.
My trailer weighs 1800 pounds loaded. I believe all non-rubi LJ's have 3.73 axle ratio. Was 3.37 just a typo?
Current: 2016 Ram 1500 Sport - Past: 05 Wrangler LJ, 90 and 92 Trackers and 98 Wrangler SE
keithert is offline
post #9 of 17 Old 12-28-2011, 05:27 PM Thread Starter
jrwdlw
Oops, I meant to type 3.73.
jrwdlw is offline
post #10 of 17 Old 12-28-2011, 08:57 PM
JohnnyWhitehead
2011 JK Wrangler
Loaded trailer is a little over 2K. I have 3.73 gears with 33 inch tires. I have the 6 speed manual and it pulls just fine. My stopping distances is much much increased.
GEAUX TIGERS!!!!
post #11 of 17 Old 12-28-2011, 09:02 PM
wushaw
Rockin jeep
wushaw's Avatar
It's no issue getting the load moving, it's the hyghway speed that is interesting on a SWB vehicle.
wushaw is offline
post #12 of 17 Old 12-28-2011, 10:15 PM
KKiowaTJ
The I-6 has been used in tractors and real pulling DD farm trucks for years and their still going strong. It makes more torque down low and a manual with a low first will more than do the job.
I wouldn't want the 42rle for towing, They need a auxiliary cooler for stock tires to keep it cool and functional. Good luck either way
MOPAR!
KKiowaTJ is offline
post #13 of 17 Old 12-28-2011, 11:25 PM
hndswthtshdws
2000 lbs isn't much of a load. Thats like a car full of fatties. Sometimes we put too much thought into things. Just drive it. Worry about stopping. Go with whatever transmission you prefer.
The old 4.0 XJ's had a towing capacity of 5000 lbs versus the wrangler 2000 lbs, even though they had the same drive line. Wheelbase and stopping ability is why.
A dealership should let you test drive both with your trailer behind it.
hndswthtshdws is offline
post #14 of 17 Old 12-29-2011, 08:11 AM
Holm-z
Holm-z's Avatar
Lol!!
1998 TJ Sport 4.0L 5spd
3.75" RC
33x12.5x15 Goodyear Duratracs
Superwinch 10000lb
Monstaliner, CB, ARB Front locker, 4.56 gears
I understand.
IAFF Local 3265
Holm-z is offline
post #15 of 17 Old 12-29-2011, 02:40 PM
Marauder_Pilot
That won't be a problem. I had to briefly tow a loaded U-Haul box trailer through downtown Chicago once. Getting moving wasn't any problem, even with being undergeared. Stopping, though...
A braked trailer will definitely help with the stopping though.
-TTAC
load squeeking noise after i shift into third gear derrickearl TJ Wrangler Technical Forum 1 05-03-2009 03:46 PM
Auto gear or Manual?? FarAway72 TJ Wrangler Technical Forum 3 04-08-2009 08:13 AM
what the best for wrangler auto or manual gear ? FarAway72 TJ Wrangler Technical Forum 0 04-07-2009 09:29 AM
4-speed auto shift via mph or Rpm/load ? sourskittle TJ Wrangler Technical Forum 14 12-11-2008 10:06 AM
Rubicon Manual vs. TJ Manual vs. 03+ TJ Auto vs. 97+ Auto 04JeepTJ TJ Wrangler Technical Forum 10 02-02-2004 02:43 PM
