Someone school me on OBA systems - Page 2 - JeepForum.com
post #16 of 26 Old 12-11-2012, 03:07 PM
ihatepiggies
I have a bait system with a 30 inch horn. I absolutely love the system very easy install and works crazy good for on the trails! PM me if your doing this and want my number to chat on it.
ihatepiggies is offline
post #17 of 26 Old 12-11-2012, 03:11 PM
ihatepiggies
Better picture of my horn. Airhornsoftexas.com good prices and he told me exactly what I needed to do to add this to my system.
post #18 of 26 Old 12-11-2012, 04:11 PM Thread Starter
Carlos14
Pm sent.
Luck Favours The Prepared
Carlos14 is offline
post #19 of 26 Old 12-11-2012, 04:13 PM Thread Starter
Carlos14
Originally Posted by Butterbuddha View Post
I have a Viair system (sold as a "JK" kit since it comes with a bracket for mounting to my crossmember in between the radiator fan and the motor, but thats it) If you have room, its pretty nice to have dual compressors mounted on a tank. Fills to 140 psi in like 20 seconds!
That is quick fill time! I've been looking at this set up via eBay... Anybody have any luck with this or similar?
http://www.ebay.com/itm/Dual-Truck-H...item1e6257e339
Carlos14 is offline
post #20 of 26 Old 12-11-2012, 05:09 PM
ihatepiggies
To run the train horn you'll need a switch, and solenoid like te one in the first pic. (Airhorn guys will hook you up on this)
If you get a vair system it comes with the gauge shown but the hose is rather short that you use to fill tires. So I got a 25 foot coiled hose for cheap. From the solenoid you will run hose through your floor (if done like me) to the horn wiring the solenoid to a switch close by so you can scare and deafen peeps
post #21 of 26 Old 12-11-2012, 05:12 PM Thread Starter
Carlos14
That gauge and switch is for your horns?
Carlos14 is offline
post #22 of 26 Old 12-11-2012, 05:20 PM
ihatepiggies
The gauge and switch with it controls the compressor. If left on it will fill to 150psi, turn off then auto cut on at 125psi. The switches in front of my shifter are (L to R) front lights, rear lights, then on the right the blue switch is always lit up controls the horn.
post #23 of 26 Old 12-11-2012, 05:21 PM Thread Starter
Carlos14
Nice! I like it!
Carlos14 is offline
post #24 of 26 Old 12-11-2012, 05:24 PM
ihatepiggies
It works well, right at the flick of a finger I can make someone soil their pants without fumbling to find a switch. Also being lit up at night helps too. Oh and the switches were bought at autozone for dirt cheap.
post #25 of 26 Old 12-28-2012, 12:48 AM
OlivergreenCJ7
Look in the Puma 12v 1.5 gallon compressors. Ito rock sells a rebadged version with all the wiring needed. 3.4 Cfm at 40 psi is faster then any other electric compressor will do. You can separate the motor from the tank as well.
1979 CJ7: Gone,but not forgotten
2001 TJ Sport: locked and loaded
OlivergreenCJ7 is offline
post #26 of 26 Old 12-30-2012, 07:21 AM Thread Starter
Carlos14
Attachment 532474
Attachment 532471
Attachment 532472
Attachment 532473
That's a great find! At only $230 I can definitely see going this route. That's a strong set up. And super quick.
Carlos14 is offline
oba , wrangler , YJ
Anyone seen one of these disconnect systems? paultyler YJ Wrangler Technical Forum 13 10-02-2006 12:13 PM
A/C systems 92Jeep2.5l YJ Wrangler Technical Forum 4 07-03-2006 11:04 PM
Air intake systems mikemac4 YJ Wrangler Technical Forum 5 11-02-2005 05:32 PM
Are all BB systems the same? mopar01 TJ Wrangler Technical Forum 5 01-24-2005 01:09 PM
Co2 air systems? sbninja TJ Wrangler Technical Forum 13 10-23-2004 09:45 PM
