Someone interested in helping a newbie? - JeepForum.com
post #1 of 4 Old 10-13-2010, 09:48 PM Thread Starter
JeepKyle
1980 CJ7
I need to know what is the proper size tire for a jeep with 4-5 inch lift and a wheel size of 15x8, if you can help me with this it will be much appreciated
JeepKyle is offline
post #2 of 4 Old 10-13-2010, 09:59 PM
Sgt.Fuzz
Fill in your profile. And if you've got the D35 rearend then stick with 33's.
My build:
Sgt.Fuzz is offline
post #3 of 4 Old 10-13-2010, 10:02 PM
06camarodude
33's would fit well with no rubbing, you could probably run 35's with no rubbing depending on the flares you run. With 4" of lift, you would need to worry about other limiting factors, not clearance. You'll need to make sure your drivetrain is up to the task of turning whatever tires you are running. Particular attention needs to be paid to the rear end, the D35 (if that's what you have) is notoriously weak, and it can't really handle more than 33" tires.
For future reference, this is a topic that has been beat to death. Next time, try using the "Search" function at the top of the page.
Check out my Gun Blog!
Originally Posted by elsapo View Post
"Do not judge, or you too will be judged." Matthew 7:1
Originally Posted by AustinTJer View Post
That's a pretty decent crawl ratio, tell Matthew congrats. :2thumbsup:
06camarodude is offline
post #4 of 4 Old 10-13-2010, 10:03 PM
g4x4xgeoff
d35 rear axle, stick to a 33" tire.
Originally Posted by Hurley91 View Post
I could be drunk, high, raped and almost dead.... and I could still recognize it.
g4x4xgeoff is offline
help needed
Helping out a stuck..... DerekXJ86 Wrangler General Discussion 5 03-13-2010 09:18 PM
Is this helping? moonshinefuel Wrangler General Discussion 16 08-12-2009 10:16 AM
JK helping out a Semi. Scooter_Trash JK Wrangler Technical Forum 5 01-26-2008 09:46 AM
Helping a Friend Scotch740 TJ Wrangler Technical Forum 1 03-21-2006 01:41 AM
Helping 2 friends buy a TJ which..... M&C_TJ TJ Wrangler Technical Forum 14 12-28-2005 05:16 PM
