SOMEBODY PLEASE HELP...Matching lift kit with rims and tires!!!!!!!!!!!!!!!!! - JeepForum.com
post #1 of 18 Old 08-28-2012, 12:58 PM Thread Starter
C-Ro
I have a 2012 unlimited sport. I just bought XD Rockstar 5x5 rims and will put 285-60 R18 Nitto Terra Grappler Tires on them.. I will do lil off roading and am looking for the best lift that will deliver the best ride. I would like to do it right the first time so I will not have to revisit. Please help, I am new to this and want to make the right buy. Thanks alot
C-Ro is offline
post #2 of 18 Old 08-28-2012, 01:00 PM Thread Starter
C-Ro
Also the rims are 18x9
C-Ro is offline
post #3 of 18 Old 08-28-2012, 01:23 PM
Sccafire
Try agan. I doubt 285/16/r18 is the tire correct tire size. That size comes out to 21.6x11.2/18. You are probably wanting 285/60/18. If that is the case then you won't need a lift.
Scott
"life is good at 2 MPH"
Sccafire is offline
post #4 of 18 Old 08-28-2012, 01:30 PM Thread Starter
C-Ro
type O.. you are correct it is 285/60/18 and I would still like a lift to give me a lil more room.
C-Ro is offline
post #5 of 18 Old 08-28-2012, 07:06 PM
scubamc
If you are going from the stock 245/75/16 tire, 30.5" tall, to the 285/60/18, 31.5" tall, it is a waste of money for a lift. You are talking about a one inch difference. With the 18" wheel and shorter sidewall your ride will be rougher than stock.
Horsepower is like a hot girl with STDs. You know you want to hit it but you're afraid of the consequences.
scubamc is offline
post #6 of 18 Old 08-29-2012, 06:53 AM Thread Starter
C-Ro
So what do you recommend...What would make since for a good look while getting a good ride for a daily driver
C-Ro is offline
post #7 of 18 Old 08-29-2012, 07:33 AM
TheRealKTrain
JK Wrangler
Why not try it stock? LOL JK drivers are funny
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." Aristotle
Μολὼν λαβέ
TheRealKTrain is offline
post #8 of 18 Old 08-29-2012, 07:47 AM
paul84043
If you go with 285's and a lift, the tires are going to look small.
285's look just about right on a stock JK. I ran my 2010 JKU like that for a couple of years.
If you're considering tires/wheels and a lift, decide how much lift you need, and then match the tires to it.
2.5" of lift will accomodate 35's nicely and things look proportional.
Make a man a fire and you keep him warm for a day....Set a man on fire and you keep him warm for the rest of his life....
paul84043 is offline
post #9 of 18 Old 08-29-2012, 09:59 AM Thread Starter
C-Ro
Sounds good. I have already bought the 18x9 rims. Do you think 35s would look good and fit on 2.5 teraflex lift. Also it calls for 4.5 inch backspace and my rims are 5 inch. Is this a problem..THanks again
C-Ro is offline
post #10 of 18 Old 08-29-2012, 10:06 AM Thread Starter
C-Ro
also, how do you think the ride will be around town. Is this a good setup.
http://www.xtremeterrain.com/jkwrang...Fce8KgodQl0AEw
C-Ro is offline
post #11 of 18 Old 08-29-2012, 10:31 AM
brplatz
Issue is you bought "bling" rims. Makes it a bit more difficult to give advice. A good ride/performace means you need to put some cash into a well built/designed suspension. 17" Rims are about the biggest people go on offroading rigs. If you wont see much offroad then it doesn't matter.
The Second Amendment is in place in case they ignore the others.
That's like saying you wish your boyfriend was a bit less gay.
MOΛΩN ΛΑΒΕ
brplatz is offline
post #12 of 18 Old 08-29-2012, 12:43 PM
4x4jkx
If you're still worried about clearance get a pair of flat fenders. They will give you another inch or two of clearance.
4x4jkx is offline
post #13 of 18 Old 08-29-2012, 03:37 PM
Prot
Prot's Avatar
2014 JK Wrangler
Here is a quick run down. JK's can come stock with 32" tires. They can fit 33's with proper backspacing. The most common size for this is 285/70-17 on a 17 X 9 wheel with 4.5" backspacing or stock wheels with spacers that get the total backspacing down to 4.5".
You already bought blingy 18 X 9 wheels. Here are the sizes and diameters for Goodyear Duratracs made for 18" wheels.
275/65-18 = 32.1"
275/70-18 = 33.2"
295/65-18 = 33.1"
325/65-18 = 34.6"
With these choices with that wheel size, I would go with 275/70-18 to give more sidewall. This would not require a lift, and a leveling kit would do nicely with this. The 295/65-18 is about the same diameter, but is wider. Both these sizes give 7.5" of sidewall.
If you go with 325/65-18, you are going to need 2.5" to 3" of lift. These are going to be about 12.8" wide.
FWIW, you can usually find Rubicon takeoffs, all five in new condition, tires and wheels for $600 or less. No lift, no spacers, or anything required.
I am a fan of Goodyear Duratrac. I used to have BFG AT and am much happier with them. I am running 315/70-17. A 17" wheel gives you more options and the tires aren't quite as expensive. I also prefer the looks, but that's just me. I am not fan of rubber band tires or small sidewalls on four wheel drives.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #14 of 18 Old 08-29-2012, 03:43 PM
Xpress
Another thing, don't put 10+ exclamation marks in your thread title, or big CAPITALIZED WORDS!!!!!!!!!!!!!!!!!!!! Nobody likes to be screamed at
All about that unibody life.
Xpress is offline
post #15 of 18 Old 08-30-2012, 06:43 AM Thread Starter
C-Ro
Thanks and got it.
C-Ro is offline
lift , lift kit , spacers , suspension
Rims/tires for 4in lift sethhawk1 TJ Wrangler Technical Forum 11 07-16-2012 03:40 PM
Lift, tires and rims are in! MMerrick YJ Wrangler Technical Forum 10 07-08-2007 06:35 PM
New Tires, Rims and Lift....Done OrionAZ TJ Wrangler Technical Forum 8 10-07-2005 09:46 PM
New tires/rims for under the new lift Molotov TJ Wrangler Technical Forum 1 06-30-2005 12:29 PM
Rims and tires w/o lift Fropleyqk TJ Wrangler Technical Forum 21 07-14-2003 03:13 PM
