Sliced window - piece of paper stolen - JeepForum.com
post #1 of 31 Old 12-04-2011, 05:45 PM Thread Starter
Chillpill109
Dear Jack *ss that slit my window for a parking permit worth $20, You’re not only the cheapest mother f***er on this planet, you are the most ignorant piece of f***ing scum. So you could save $20 you slit my window that I can only buy new in pairs at the lovely cost of $280. So, in reality you saved yourself $20 at my expense of $300 + shipping and handling. Just to make it quite obvious because apparently its not, my windows have zippers. HOLY S**T WHAT A CONCEPT. I don’t care about the ticket man keep it. Just unzip the window next time ok? Maybe if you weren’t trying to be such a bad *ss and slit someone’s window for a parking ticket you would have notice the door wasn’t even locked. So thank you prick I hope you enjoyed the Judas Priest concert because Karma is a f***ing b***c. Let’s just hope your throat doesn’t turn out like my window in the future.
Chillpill109 is offline
post #2 of 31 Old 12-04-2011, 05:50 PM
Spuznick242
Feeling better now? Someone stole my glasses from my topless jeep one day...pissed me off as all hell, hopefully you can figure something out, how about repairing the window? I was just thinking about a tent repair kit and how it would work on repairing a soft top...actually now that I think of it I work and operate one of these in the winter...http://www.bigairbag.com/ When they get holes every now and then from sharp skis and board edges we use a hot air gun to melt a new piece of plastic over the rip on the under side of the top layer...its strong as can be and if your good at it you dont even need to add a peice of plastic, just melt the two pieces together into an almost invisilbe seam.
DD- 1995 YJ 2.5L, Cat delete, 19lb injectors, 30/9.5r15
Trail Rig- 1994 YJ 4.0L, Rubicon Express 4.5inch lift, 1inch body, D30 Aussie, 33/12.5/r15 Cooper Mud Terrains, front bumper, rocker guards
Spuznick242 is offline
post #3 of 31 Old 12-04-2011, 05:53 PM
dillonjm
2013 WK
Its ****** nozzle, self entitled, jack holes like this that piss me off the most.
"Gimme that worthless piece of junk that I think I deserve because mommy told me I'm special. Oh, its inside something that someone else owns that I can't afford, so I don't think they deserve it either? Well, I'll fix that, I'll destroy it."
****ing *******s
Whatever happened to working hard to EARN what you want?
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #4 of 31 Old 12-04-2011, 05:57 PM Thread Starter
Chillpill109
yeah i feel a lot better haha i was going to cut off the stretched out part where they dug their key into it and glue a piece of my old window over it to patch it but should i use a heat gun to melt the plastic already there or add plastic?
post #5 of 31 Old 12-04-2011, 06:07 PM
Spuznick242
Well I would go to home depot and buy a similar plastic piece and try to patch a slice in that first by just melting the two together or by adding a piece behind it and melting that in...and if that does work then just junk your piece of plastic...if you need backing, use the peice that you bought as the backing. PM and I can explain better on how we do it at work, we use a special compressor that shoots out hot air but I'm sure you can achieve the same effect with just a heat gun.
post #6 of 31 Old 12-04-2011, 06:36 PM
YJSteveD
That sucks man. I seriously hate people like that.
I just bought a YJ today and I don't know if one of the soft windows will fit my doors. If it doesn't, I'll shoot you a message and we'll see if it'll fit yours. If it does, I'll send it down to ya
YJSteveD is offline
post #7 of 31 Old 12-04-2011, 06:47 PM
Old4X
1990 CJ7
Convertible tops have been getting slashed for the last 80 years or so. Sucked then, still sucks now.
An upholstery shop should be able to sew a patch on it. Won't look perfect, but will work till you can find a cheap replacement on Craigslist or here in the classifieds.
Good luck.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #8 of 31 Old 12-04-2011, 06:49 PM Thread Starter
Chillpill109
thanks steve i appreciate it
spuz, i just tried using a heat gun on an old window i kept from my old top. ( everyone thought i was crazy for keeping my old stuff) the heat gun gets way too hot even on the lowest setting it just burns the plastic i tried cutting a piece of the plastic window out and get it to melt to itself but it won't stick. Since i am in miami i may be able to find a boating place that will be able to fix it for me.
post #9 of 31 Old 12-04-2011, 06:52 PM
njfreekshow
2008 WK
my wife and i have talked about this before (she has a soft top TJ) and its retarded people slice the windows instead of opening the door or just unzipping the damn thing. hopefully you can fix it or find a window local.
08 WK Laredo 3.7L
99 XJ Sport with a 3.5" Rusty's Suspension lift on 31x10.5 Pro Comp MTs (sold)
njfreekshow is offline
post #10 of 31 Old 12-04-2011, 06:54 PM
Old4X
1990 CJ7
Supposedly it is PVC plastic. I have never tried it, but it is possible glue for PVC plumbing pipe will bond it. If you have some scraps, it is worth a try.
Old4X is offline
post #11 of 31 Old 12-04-2011, 07:48 PM
aeroyj
Somebody cut my window just inside the zipper, all the way around so that it would fold down. And they didn't take a thing. That was 2 or 3 years ago now and it has been held together with duck tape ever since. The only thing I hate more than having my stuff taken, is having it destroyed.
One of the most maddening thing about 1990s American cars is the mixture of metric and SAE fasteners throughout, as Detroit gradually shifted over to the standards system favored by Communists, criminals, and the morally bankrupt. -Murilee Martin
aeroyj is offline
post #12 of 31 Old 12-04-2011, 08:07 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
OP: why don't you do what we all do when this happens and put it on craigslist? Ya know, minus the death threats. I doubt anyone on here actually stole it. If they did they would have been smart enough to gank your doors while they were at it.
At this time I would like to clarify that I haven't been in Florida in four years.. It wasn't me.
Luck Favours The Prepared
Anticanman is offline
post #13 of 31 Old 12-04-2011, 08:41 PM Thread Starter
Chillpill109
LOL Anticanman thats how i know it wasn't a fellow Jeeper. We know how to get into each other's rigs respectfully and know what to take when we do
post #14 of 31 Old 12-04-2011, 08:43 PM
Twiddler
People Suck. I added a motion sensor to my ride and never lock the doors but all this does is make a bunch of noise after the damage is done. I feel ya brother. Maybe he will catch syphilis and his balls will fall off...that's fair...
Twiddler is offline
post #15 of 31 Old 12-04-2011, 08:43 PM Thread Starter
Chillpill109
That would have made me even more mad -___-
If it is the passenger side and OEM style top i have a perfectly good skin i can mail you ^_^
So, I was doing research for a paper today and found this historical technical piece. Charles JK Wrangler Technical Forum 18 10-15-2010 12:51 PM
Cracked/Sliced Soft top back window jgowen TJ Wrangler Technical Forum 2 04-06-2010 07:05 PM
Houston- Stolen Pass Side Window Red Rubycon Wrangler General Discussion 8 04-03-2009 12:32 PM
missing rear window piece? TheNewbie YJ Wrangler Technical Forum 12 03-11-2009 09:39 PM
Stolen Soft Top Window Panel Special K TJ Wrangler Technical Forum 8 01-11-2008 07:37 PM
