simple off roading questions. - JeepForum.com
post #1 of 11 Old 01-23-2009, 01:58 PM Thread Starter
jimG16
Say your off roading you see a huge mud hole, pretty deep and decently long. You have to try it:
-4low or 4hi, and what gear in each.
-shifting IN the hole, bad or ok idea.
-how fast to hit it, creep in or fast.
-how deep can one go before running into some major problems.
I have a manual.
jimG16 is offline
post #2 of 11 Old 01-23-2009, 02:02 PM
Niceface
4low and second for me
Never shift in a hole. You will stop quickly
creep in. Never know whats lurking at the bottom
If you bury the axles, your in trouble.
I drive a i6 manual. hope this helps.
Niceface is offline
post #3 of 11 Old 01-23-2009, 02:25 PM Thread Starter
jimG16
I know the hole very well, nothing is down there i wouldnt know about. My buddy went through in a huge sami. I dont wanna get stood up to by that. He hit it fast and shifted from 2nd to 1st in 4hi and had clutch problems the rest of the day.
jimG16 is offline
post #4 of 11 Old 01-23-2009, 02:57 PM
p-rev
yeah dont ever shift in mud or water unless you really want to replace your clutch.
p-rev is offline
post #5 of 11 Old 01-23-2009, 03:19 PM Thread Starter
jimG16
so going in is fine say up to my air intake but if i get stuck dont shift gears, get someone to pull me out?
jimG16 is offline
post #6 of 11 Old 01-23-2009, 03:23 PM
HITMONEY
RubiKong's Trainer
HITMONEY's Avatar
Naaaa leave it there as a monument!
LOL!!
I wanna see pictures of this hole!!
I Wheel a Wave Killer!
08 Unlimited RubiKong
Pics And Info Of My Junk
YouTube Channel
FaceBook
HITMONEY is offline
post #7 of 11 Old 01-23-2009, 03:45 PM
MLJeeper
MLJeeper's Avatar
I know the hole very well, nothing is down there i wouldnt know about. .
Keep thinking that . Ive been stuck in a hole i "knew" . Apparently, Some yahoo came by with some big boggers and ate the hole up. Went in and sunk.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #8 of 11 Old 01-23-2009, 03:47 PM
IslandTJ
This happens alot.
Now Jeeping in Oregon
IslandTJ is offline
post #9 of 11 Old 01-23-2009, 03:49 PM
gribbles
dont shift and if you are familiar with the hole then go in with some decent speed, but not fast by any means. you want to create a small wave in front of the jeep to help clear some water and things away, but again, not fast
2000 TJ, 100" wb on leaves
2007 WK CRD
gribbles is offline
post #10 of 11 Old 01-23-2009, 04:44 PM
Trombino
Trombino's Avatar
1978 CJ7
At least the Sammy wasn't a Hummer. In fact, you might want to make sure that Sammy is there for when you are floating in that hole and need a pull.
'78 CJ7 -- Chevy 350 SBC, Holley 4-BBL, TH700R4, B&M Performance Shifter, Dana 300 w/ Twin Sticks, 3" Shackle Lift, 3" Body Lift, D30 Front (Disc), AMC 20 Rear w/ Moser 1-Piece, 4.10's, 35x12.50/15 General Grabber MT's, Cragar Soft 8's (15x8 w/ 4" BS)
Trombino is offline
post #11 of 11 Old 01-23-2009, 05:15 PM
BWFBezerk
I have an '04 SE, 5-speed......I found a big mud puddle too:
I hadn't learned yet not to shift under water. I shifted into 1st and reverse many, many times, as well as 2Hi, 4Hi, and 4Lo many many times. I've yet to have any problems relating to the clutch, but my power steering pump whines like a banshee now. I have a Cherrybomb Glasspack on my Jeep, and at 3k RPM and up all you can hear is my power steering pump.
I was extremely lucky as not to have any bigger problems than that. All my fluids except power steering were ok, had to drain that system out. Still whines though
BWFBezerk is offline
Couple Questions about Off-Roading Florida_Model TJ Wrangler Technical Forum 26 06-04-2009 06:11 AM
2 simple questions joeyrossmiller YJ Wrangler Technical Forum 2 03-10-2009 08:02 PM
two simple questions? jeep2008 TJ Wrangler Technical Forum 17 08-22-2008 03:00 PM
A few simple questions yjing YJ Wrangler Technical Forum 11 11-14-2006 06:44 AM
simple questions nick_25 TJ Wrangler Technical Forum 7 04-09-2006 02:44 PM
