Should I put 17" JK rubicon wheels on my 2004 Jeep TJ? (merged) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > Wrangler General Discussion > Should I put 17" JK rubicon wheels on my 2004 Jeep TJ? (merged)
Poison Spyder from CCOR!Oconee Offroad Sales Tech are Available To Help!Free shipping on slip yoke eliminator kits New lower Price
Unread 09-06-2012, 07:26 AM   #1
rubiconjeep1992
My 2004 Jeep tj has a 4" skyjacker lift on it. I am getting new 35" Toyo Mt tires Saturday and I bought a set of 5 JK rubicon wheels for $50 off craigslist earlier this year. I already had the adapters on my jeep but I was wondering whether you all think I should run the jk stocks, or keep my 17" pro comp wheels? Also, if anybody has any pictures of JK wheels on a TJ that would help me out a lot. Thank you!
rubiconjeep1992 is offline   Reply With Quote
Unread 09-06-2012, 07:30 AM   #2
rubiconjeep1992
Jeep JK rubicon wheels on a TJ?
Unread 09-06-2012, 08:05 AM   #3
PFCJoker
PFCJoker's Avatar
Do you have an overwhelming urge to pay more for tires?
EDIT: I should read more gooder.
Already has 17" duh
PFCJoker is offline   Reply With Quote
Unread 09-06-2012, 08:33 AM   #4
hustler905
^ He already has 17" rims and tires.
I just bought some JK Rubi wheels, and I think the big issue is the crazy amount of backspacing (6") they have. I have a 285/70/17 on the way for them and it should just clear, given some 1.375" Spidertrax spacers that will also serve as adapters.
With a 12.5" wide tire you may be into some issues fitting around coil buckets and stuff.
hustler905 is offline   Reply With Quote
Unread 09-06-2012, 08:37 AM   #5
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
JK wheels have a 5x5" bolt pattern which will not fit on a TJ which has a 5x4.5" bolt pattern.
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is online now   Reply With Quote
Unread 09-06-2012, 10:04 AM   #6
monsonman
people call me monson
monsonman's Avatar
did a quick photo shop of jk wheels for you
'98 TJ- it has a lift, 4wd, and some other stuff
RIP- '61 CJ5 on tons, coilovers, t-18 with granny 1st, dana 20 with 4:1, psc full hydro, 39.5" iroks on h1 beadlocks - TRADED FOR TJ
RIP-'79 CJ7 304 V8, twin sticked 20, 36" Iroks - SOLD
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf."
-George Orwell
monsonman is offline   Reply With Quote
Unread 09-06-2012, 10:11 AM   #7
DirtRider1357
i have jk wheels with 265/75/r17 bfg km mud tires, and spidertrax 1.5inch adapters on my 05 lj (stock) and they rub on my control arms at full lock.
87 YJ, 4.0L, 5speed......sold, 05 LJ Rubicon
"It'll buff out"
"If it moves and shouldn't, use Duct Tape & Zip Ties. If it doesn't move and should, use WD-40 & A hammer"
DirtRider1357 is offline   Reply With Quote
Unread 09-06-2012, 03:08 PM   #8
rubiconjeep1992
wow thanks a lot man! that looks good to me! I will get them put on this weekend now lol
Unread 09-06-2012, 03:40 PM   #9
rubiconjeep1992
will stock jk rims fit on a 35x12.5x17" tire? Help please!
If i get 35x12.5x17 Toyo mud terrain tires and I want to put stock Jk wheels on them (already have the adapters to make it fit on my Jeep TJ), are the jk wheels wide enough to fit inside of a tire that has a 12.5 width? or will i have to get tires that are smaller? someone help please
Unread 09-06-2012, 03:43 PM   #10
rubiconjeep1992
Unread 09-06-2012, 03:54 PM   #11
Jerry Bransford
The width of the adapters will be the key determining factor. Guessing the JK factory wheels having a similar amount of backspacing the TJ factory wheel has, you'd need adapters that are approximately 1.25" to 1.5" wide to give the tire's inside sidewall sufficient clearance away from everything.
Getting Savvy...
Unread 09-06-2012, 04:15 PM   #12
hustler905
JK Rubis have 6" or 6.25" BS and a re generally 7.5" wide, depending on what year. Are these the rims you have decided on?
If so, the widest adapter I have found was 1.5". You might have a hard time fitting 37 x 12.5 on a net 4.5" BS wheel.
Unread 09-06-2012, 04:16 PM   #13
hustler905
You should get the same answers as your thread in the TJ section.
Unread 09-06-2012, 04:17 PM   #14
rchase559
How wide are the rims?
rchase559 is offline   Reply With Quote
Unread 09-06-2012, 04:25 PM   #15
Necko2529
Necko2529's Avatar
He's wondering if the tire will fit on the rim and not the Jeep.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
Necko2529 is offline   Reply With Quote
