Sad day for me - Page 2 - JeepForum.com
post #16 of 31 Old 12-11-2010, 02:31 PM
pdm66
cam Synchro
pdm66 is offline
post #17 of 31 Old 12-11-2010, 02:33 PM
theducksguts
Originally Posted by pdm66 View Post
cam Synchro
not on a 95. A cam Synchro basically tells the Jeep's computer what position the cam shaft is at. I think they started using them in 00 when they went to Coil Pack ignition.
Check out my
theducksguts is offline
post #18 of 31 Old 12-11-2010, 04:09 PM
Sgt.Fuzz
Originally Posted by theducksguts View Post
A camshaft? I hope so.
My build:
Sgt.Fuzz is offline
post #19 of 31 Old 12-11-2010, 04:28 PM
Jet300
Originally Posted by mafbowhntr View Post
Cam syncro failed last night on my way home causing my motor to lock up.I did not even have time to pull over as soon as the syncro failed it was to late already lost oil pressure.My poor Jeep only had 93,000 on it so now I am gone to see what Chrysler says .
Why would a sensor failing / breaking / snapping, etc. cause the motor to loose oil pressure and lock up? I mean an engine wont lock up immediately upon loss of oil pressure? I can see immediate stalling due to the PCM not geyting its inputs to fire injectors and spark ....
I'm looking to learn here .. the only thing I ever heard of breaking and immediately killing a motor is when a timing belt snaps on an interference type engine ... Even then all it really does it mash up the valves in the head ...
Confused here ...
Jet300 is offline
post #20 of 31 Old 12-11-2010, 05:06 PM
trw
2011 JK Wrangler
Confused here ...
A cam synchronizer replaces where once was a distributor, it is driven by the camshaft.
the oil pump is driven off the same shaft that the cam synchronizer uses, which is driven off a gear on the camshaft. The drive gear on the cam synchro is what is prone to failling on late model TJs, not the sensor itself, so when the gear goes, so does the oil pump (and gear on the camshaft as well), boom, bye bye engine.
Jeep garage:
2011 Jeep Wrangler JK - 33" BFG KM2s, 2.5" RC BB, ARB bumper, IPF 900XS, Superwinch EPI 9.0, AEV Snorkel
1995 Jeep Wrangler - 4 cyl, 2.5" lift, BFG AT 30s, Ford 8.8, SYE+CV, AX15 swap, ARB snorkel, Aussie locker + loads more - sold
1978 Jeep CJ-7 - 304 V8, TH400 auto and quadratrac
2007 Jeep Liberty - Mother's Jeep, BFG ATs and....mud?
trw is offline
post #21 of 31 Old 12-11-2010, 07:48 PM
willydigger
I felt the engine miss and it was to late,so I had a freind of mine tow it home looked at this morning shaft was broke on it ,and yes I am thinking of stroker if Chrysler doesn't want to do anything about it
The gear was broke or the shaft was broke? This is a common (too common) problem with 05-06.
http://www.jeepforum.com/forum/f9/ch...d-read-963235/
You are out of warranty with your mileage and there is no "recall" for the OPDA (oil pump drive assembly). The dealer was only marginally helpful with me and I was still under warranty when mine failed. Fortunately for me the OPDA began to squeak like a bad belt. When I pulled it there was binding in the shaft and substantial wear on the gear teeth.
Good luck to you.
willydigger is offline
post #22 of 31 Old 12-11-2010, 10:18 PM
jkp
Need to file a complaint here:
https://www-odi.nhtsa.dot.gov/ivoq/
'92 Islander
'06 Rubicon
jkp is online now
post #23 of 31 Old 12-11-2010, 11:48 PM
Jet300
OK cool. THAT makes sense. I appreciate the explanation.
Jet300 is offline
post #24 of 31 Old 12-12-2010, 01:45 AM
LABoarder
Junior Member
sorry to hear that
LABoarder is offline
post #25 of 31 Old 12-12-2010, 11:43 AM Thread Starter
mafbowhntr
that is pretty much what mine looks like sorry I cant upload pics right now
mafbowhntr is offline
post #26 of 31 Old 12-12-2010, 11:48 AM Thread Starter
mafbowhntr
Wish my jeep was sitting in a nice warm garage right now where I could work on it,18 degrees is a little bit to could to work on any thing outside
post #27 of 31 Old 12-12-2010, 01:31 PM
willydigger
Please take pics of the damaged OPDA. We need some pics of what a failed unit internally looks like.
post #28 of 31 Old 12-18-2010, 02:27 PM Thread Starter
mafbowhntr
finally uploaded pics of cam snychro
post #29 of 31 Old 12-18-2010, 02:29 PM Thread Starter
mafbowhntr
so that pretty much explains why I had catastrophic engine failure
post #30 of 31 Old 12-18-2010, 08:01 PM
Davemac85
I would use this as a perfect excuse for a 4bt swap ... thats me tho' good luck on the dealership!! hopefully you get everything taken care of
06' Wrangler/ Zone 4.25 combo/MML 33x12.50 BFG AT's. w/ Painted canyons/ other stuff
04' Grand Cherokee- Mommy mobile -
USN Jeep Club
Davemac85 is offline
