rock crawler project - JeepForum.com
post #1 of 6 Old 06-15-2011, 07:49 AM Thread Starter
OutlawsCrawl17
1982 CJ7
Im going to be putting a 4 inch lift on my wrangler. My goal is to make a rock crawler. I was Wondering if anyone whose had some experience with this could give me a list of some unforseeable parts that im going to need to replace/ upgrade for this too work, it'd be greatly appreciated.
OutlawsCrawl17 is offline
post #2 of 6 Old 06-15-2011, 07:51 AM
justanotherjpr
Steering, Dana 30 and Dana 35 are the parts you will break first.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #3 of 6 Old 06-15-2011, 08:12 AM
Imped
Imped's Avatar
You need to do A LOT of research. Read build threads, learn as much as possible.
OlllllllO
IndyORV
Imped is offline
post #4 of 6 Old 06-15-2011, 08:16 AM Thread Starter
OutlawsCrawl17
1982 CJ7
I've done lift kits before and i know theres complications. i was mainly wondering since im goin up 4 inches if theres a general preference to deal with the height to width ratio... do people usually just buy the wider tires or use axle spacers, etc. cause i dont want it feeling unbalanced.
post #5 of 6 Old 06-15-2011, 08:17 AM
Evian
Axles, regear all the axles, suspension, armor, bumpers, steering, and a loving wife that will allow you to spend that much on a Jeep. If you are married and don't have the last item on the list you will regret starting this project.
Evian is offline
post #6 of 6 Old 06-15-2011, 08:23 AM
GrouchyTim
Go spring over axle. You'll get way better flex and about an extra inch of center clearance. And it's not as hard as everyone thinks it is. No better bang for your buck. And since you say rock crawler, flex is where it's at. Lift spring don't flex well at all. SOA is where it's at.
'88 YJ with SOA and SYE and a bunch of custom crap from BWF in Chesapeake.
'97 XJ on 8" lift, double triangulated rear, long arm 3 link front, Eaton/60 with 5.14 gears.
GrouchyTim is offline
lift kit advice , rock crawler
Anyone tried the Fabtech YJ rock crawler kit? zac87 Wrangler General Discussion 1 04-09-2009 07:43 AM
rock crawler? :) Conti31 Wrangler General Discussion 21 02-13-2009 03:44 PM
Rock Crawler Wheels Dines TJ Wrangler Technical Forum 1 07-18-2008 01:09 PM
Unlimited Rock Crawler jeephreak TJ Wrangler Technical Forum 5 09-13-2004 06:52 AM
about to buy some rock crawler rims joeyt17 TJ Wrangler Technical Forum 3 05-29-2004 11:41 AM
