Ride without spare tire - JeepForum.com
post #1 of 26 Old 05-13-2013, 08:33 AM Thread Starter
REPPO
Who rides without the spare on the back? Anyone got pics? Pros/cons...besides the obvious no spare tire.
REPPO is offline
post #2 of 26 Old 05-13-2013, 09:14 AM
tyvanwie
Pros:
Lighter
Looks better IMO
Technically better visibility
Less weight o the tailgate
Cons:
No spare tire
Up to you whether you want to risk it or not. I do.
Sent from my iForum using JeepPhone
tyvanwie is offline
post #3 of 26 Old 05-13-2013, 01:01 PM
Tbasham
I always have a spare tire when I am taking long trips. Only time i ride without a spare is when I am just staying with in 10 miles of my house. The one thing i will never understand is why people will upgrade to larger tires except for the spare. I wonder what it would be like driving with a 35 on one side of the axle and then a stock 29 on the other side.
Tbasham is offline
post #4 of 26 Old 05-13-2013, 01:05 PM
cyberpyrot
looks like you got a Pimp Limp!
I have attention defiiiii hey is that a rabbit?
Thought of the day
Trust people who like big butts they cannot lie...
cyberpyrot is offline
post #5 of 26 Old 05-13-2013, 01:10 PM
Rproject
1987 YJ Wrangler
I'll never ride without a spare. Ever. One piece of junk in the road, or pot hole you didn't see until it was too late, and you're done. Stuck in the middle of nowhere, or worse - ghetto land, with no way to get home.
I too don't understand upgrading without upgrading the spare. I was recently out on a trip where a guy with a "p**ile extension" Ford F-250 had a stock spare and blew a bead less than 10 minutes into the trip. We had to tow his sorry a** back to the barn so they could fix his tire while 90% of us went on. Dumb***!!!!
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #6 of 26 Old 05-13-2013, 03:54 PM Thread Starter
REPPO
I was thinking just for daily driving around town. not out of town. and AAA?
REPPO is offline
post #7 of 26 Old 05-14-2013, 12:14 AM
frenchy206
I haven't removed the spare, however I've never needed to use it...yet. I do, however, keep a plug set, with appropriate tools, to fix the flat, on the spot. I've even done it without needing to remove the wheel. A great thing to have.
03 TJ Rubicon
frenchy206 is offline
post #8 of 26 Old 05-14-2013, 04:26 AM
AveCat
Couldn't agree more.
2012 Wrangler JK 3.6 W/ 6 Speed bought 2/15/13
2.5" Rock Krawler Lift - Bilstein 5100s - 315/70/17 Duratracs - AEV Control Arms
TruckLite - Rigid
AveCat is offline
post #9 of 26 Old 05-14-2013, 06:13 AM
Remmy18
Currently I run the stock BFG as a spare running 35s. I've debated ditching the spare altogether. I've seen oversize spares rip off the carriers from rocks, break off in prerunning scenarios, get guys hung up on obstacles, and bend stock tailgate sheet metal way more times than I've seen beads or sidewalls rip. I do live in FL tho so the terrain is mostly sugar sand and mud. Actually mounting and running a stock spare with oversized tires will look ridic but the same as running a donut on a car. Doable in a pinch, I certainly won't engage my lockers. I also carry a plug kit and needed it once from a nail in the tread, not sidewall. I am considering mounting one of my 35s that is close to wearing out as a spare but that means big $$ for some type of carrier or use valuable space to carry inside. I guess it's down to priorities for me and this just isn't one.
Remmy18 is offline
post #10 of 26 Old 05-14-2013, 09:44 AM
ncb
Seems like the electronic drivetrain systems would freak out running a smaller spare tire.
ncb is offline
post #11 of 26 Old 05-14-2013, 11:31 AM
Remmy18
Good point. I wouldn't run far like that. Just limp a few miles to a tire shop if need be.
Remmy18 is offline
post #12 of 26 Old 05-14-2013, 11:35 AM
mello
Smaller can cause trac control and abs to be confused and probably will. On a vehicle with auto 4wd it can cause 4x4 to kick in going down road. Also diff carriers will not like one tire going more revolutions than the other.
mello is offline
post #13 of 26 Old 05-14-2013, 11:37 AM
222Doc
222Doc's Avatar
and spider wear even could break a spider.
A spare is like a winch or a fire extinguisher a weapon. The one time you do need it and do not. Your stuck, your Jeep burns to ground, you are dead.
222Doc is offline
post #14 of 26 Old 05-14-2013, 03:20 PM
Ross
I run 33X`12.5 on the jeep but have a 33x9.5 BFG MT spare on the stock tire. It has been there about 12 years now. It is covered so it shouldn’t rot. I choose this tire because it was very light (almost paper thin sidewall) compared to other similar size tires.
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is offline
post #15 of 26 Old 05-14-2013, 03:47 PM
bfaas
I keep my spare in the back (backseat removed). A 33 fits nicely between the wheel wells.
bfaas is offline
