Removing undercoating overspray safely - JeepForum.com
post #1 of 4 Old 01-22-2017, 12:12 AM Thread Starter
TheBoogieman
The Devil's Advocate
TheBoogieman's Avatar
Anyone know how to safely remove undercoating overspray? The PO of my newest Jeep had bad aim and sprayed the crap all over the firewall from underneath. Thanks.
TheBoogieman is offline
post #2 of 4 Old 01-22-2017, 03:36 AM
lloydsmale
2015 JK Wrangler
a rag soaked with gasoline or mineral spirits would probably work.
2015willys 4 cyl tj 2017 silverado yamaha grizzly, Polaris rzr 04 z06 vette, 600/800 crossfire cat
lloydsmale is offline
post #3 of 4 Old 01-22-2017, 01:09 PM
2jhanna
Define safely. I find gas will dissolve most tar based coating. Maybe put some in a spray bottle and keep it wet, then use some hi pressure water.
jhanna
denton county, tx
2jhanna is offline
post #4 of 4 Old 01-24-2017, 09:56 AM Thread Starter
TheBoogieman
My overspray was thick! Not just a little crap. I used Goof Off Pro Strength Cleaner $6 at Lowes.It ate through the thickest crap and just started dripping away with no brushing or wiping. The carwash pressure hose did the trick.
