Possible Issues with 32x11.5 Tire on Stock Wheels - JeepForum.com
post #1 of 5 Old 07-24-2013, 08:13 PM Thread Starter
cdohrmann
I am currently running 31x10.5 tires and a 2" BB. I am planning on purchasing new tires in the next week and would like to move up to 32x11.5. I have a set of stock aluminum canyon rims (15x8 with 5.5in backspacing I believe) I don't have any issues with clearance or rubbing as of now but I just want to make sure that I wont run into any issues with the larger tires. My main concern is if the backspacing on the rim will work for the larger tire. Any input from experience with the issue is appreciated. Thanks!
cdohrmann is offline
post #2 of 5 Old 07-25-2013, 11:19 AM
wwch99tj
Chances are they will rub the spring perch in the rear
Sent from my Samsung Galaxy S3 using JeepForum
wwch99tj is offline
post #3 of 5 Old 07-25-2013, 05:44 PM
grogie
M-F: Cell Block #4533
grogie's Avatar
Agree, chances are they'll rub. I have 32s and I did buy new wheels. I bought a set of five American Eagle alloy wheels for under $400 (plus they're made in the USA). 4.5" bs or less would be good.
Just another Jeep expense.
Red Jeep Club #345
2006 TJ Sport -
2004 KJ Limited
2013 Off-Road Trailer -
from the onslaught of young idealists. -- Don Colacho
grogie is offline
post #4 of 5 Old 07-26-2013, 10:36 PM
smokeybear
mine just cleared the rear spring perch by about 1/2 inch. I did rub the control arms up front when turning. Had to put a couple washers on the steering stops to compensate. Finally got wheel spacers and took off the washers, but it worked fine without the spacers.
02 TJ Sahara 4.0 5 spd, 3.73, Dana 44 rear, 2.5" lift w/ Bilstein shocks, 33x12.50
smokeybear is offline
post #5 of 5 Old 07-29-2013, 04:38 PM
Marauder_Pilot
Marauder_Pilot's Avatar
I have that exact setup right now. Stock, you'll rub on hard turning. Not going to be a serious issue, but it makes hard turns, parking, ect a little bit of a pain.
I installed a set of 1.25" spacers to deal with it, and it works just fine now.
"Buying a Jeep for on-road handling is like downloading porn to savor the cinematography."
-TTAC
2000 Jeep Wrangler TJ Sport-OME HD Lift, ProComp bumper, 32" BFG TA K/Os
2010 Kawasaki KLR650-Stock
2006 Ford F-250-Stock
Marauder_Pilot is offline
backspacing , budget boost
