overheating? - JeepForum.com
post #1 of 9 Old 08-15-2009, 08:42 AM Thread Starter
Mudzilla6661
2010 JK Wrangler
overheating?
My girlfriend just got her wrangler its a 2002 tj 4 banger auto. anyway we were driving yesterday for a little bit when it suddenly started getting really hot. It did this the other day too we had to let it cool down before we drove it home. It has plenty of coolant, and the radiator looks fine. The other day when it got really hot and then we turned it off we could hear something boiling like the radiator fluid or something. any clue what this problem could be? I was thinking it could be the thermostat is just not working correctly so it wouldn't release coolant into the engine when it got hot? how do you tell if it is the thermostat? what else could it be?
thanks
Kyle
2010 jk islander aka Mudzilla 2.5 AEV lift 35" kevlars, PSC front and rear bumpers Q10000 winch. More to come!
Mudzilla6661 is offline
post #2 of 9 Old 08-15-2009, 10:00 AM
daggo66
2009 JK Wrangler
There's no test for a thermostst that I'm aware of. The part itself is cheap, but replacing the coolant isn't. Have you checked for any leaks?
Tom
daggo66 is offline
post #3 of 9 Old 08-15-2009, 10:00 AM Thread Starter
Mudzilla6661
2010 JK Wrangler
i haven't seen any leaks anywhere yet. I will check again though
post #4 of 9 Old 08-15-2009, 10:20 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
what color is the coolant? is there any brown mud in the overflow container? if so, its likely your coolant's pH is f'ed causing some rust inside the block, heater, etc and could be causing a clog in the system. you'll need to flush the fluid system completely with garden hose, then install new coolant. if you need to replace the thermostat anyway, this is the perfect time to flush the whole system.
http://www.youtube.com/watch?v=tVWzn...eature=channel
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #5 of 9 Old 08-15-2009, 11:43 AM
daggo66
2009 JK Wrangler
Whatever you do, do not let it run hot until you find the cause. It could cause head warping issues, especially on a 4.
Tom
daggo66 is offline
post #6 of 9 Old 08-15-2009, 04:49 PM
jay-h
The intermittent aspect sounds like a thermostat. I'd replace that first.
jay-h is offline
post #7 of 9 Old 08-15-2009, 05:02 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
If you are boiling, something is blocked up. I would replace the thermostat and check your hoses. You also will want to make sure you put 50/50 back in.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #8 of 9 Old 08-15-2009, 07:49 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Actually, you can test a t-stat at home with a pan of water on the stove top, and a cooking thermometer.
It's even a good idea to test the new ones, plenty of folks have gotten brand new defective t-stats.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #9 of 9 Old 08-15-2009, 08:33 PM
rustywrangler
Max
I have had two new ones fail in on the stove right out of the box.
overheating? attackcammel TJ Wrangler Technical Forum 7 07-04-2010 11:58 AM
overheating 87 danthman YJ Wrangler Technical Forum 6 03-05-2009 06:44 AM
overheating, only at 55+mph ...? TXjeepTJ TJ Wrangler Technical Forum 7 09-19-2007 07:55 AM
overheating once again... sandman'sjeep YJ Wrangler Technical Forum 25 03-20-2006 03:47 PM
Overheating Kel Dub TJ Wrangler Technical Forum 7 01-21-2006 02:25 PM
