Orfab tire carrier - JeepForum.com
post #1 of 14 Old 02-01-2014, 04:44 AM Thread Starter
BobA
Orfab tire carrier
Is anyone using the orfab tire carrier? Im looking at getting the one without the jerrycan holder so the tire wont stick out so far.
Wonering how it holds up over time. Thanks.
01 TJ Sahara
6cyl. 5spd, D30 Aussie/D44 LSD,4.56 gears, RC2.5" lift, RC1.25" body lift, 33's
77 DJ5
Soon to be streetrod
BobA is offline
post #2 of 14 Old 02-01-2014, 07:44 AM
1222
RIP John
1222's Avatar
Iím not using one but I can tell you that they have been selling those for many years. I saw my first one at a SEMA show over 14/15 years ago that was for a CJ-7 and of all the manufactures that had their carriers on display ORFAB was the only one that did not rattle.
The basic design has not changed and thatís a plus. It comes with lots of internal bracing and brackets, takes a while to install but is worth the effort in my opinion.
(2011-2016)
1222 is offline
post #3 of 14 Old 02-01-2014, 08:59 PM
Clodhopper
I have had one for 3 years. It is the one with can carriers and I haul 5 gallons of gas, 5 gallons of water, Hi lift, shovel and a 32 inch spare. No rattles or any other problems, love it!
Clodhopper is offline
post #4 of 14 Old 02-01-2014, 09:42 PM
TrailDuty
2011 JK Wrangler
I run the OR Fab with Rotopax, have for over a year and a half, and no rattles or squeaks, even when fully loaded with 6 gallons of gas + a hi lift + a 100 lb spare. Love it.
TrailDuty is offline
post #5 of 14 Old 02-03-2014, 11:47 AM
HOKIES2010
2011 JK Wrangler
Had mine for 2 years. No issues. Pain to install and get setup but nice once its it on.
My Build
Couldn't have done it without
HOKIES2010 is offline
post #6 of 14 Old 02-03-2014, 11:49 AM
purplepig
same here! No problems at all, but it was a chore to install. I run the one with the jerry can holder.
purplepig is offline
post #7 of 14 Old 02-04-2014, 03:45 PM Thread Starter
BobA
Thanks for the input. Im hoping it'll clear my garvin roof rack post's.
01 TJ Sahara
77 DJ5
BobA is offline
post #8 of 14 Old 02-14-2014, 05:25 AM Thread Starter
BobA
Going to order it tonight. Think I will go with the jerry can one but use that space to hold my softdoors when they're off
01 TJ Sahara
77 DJ5
BobA is offline
post #9 of 14 Old 02-14-2014, 09:15 AM
Bowshock
WARNING!! I sent an e-mail to OR fab about mounting this with a Garvin Expedition rack on my TJ. They said based on the photos they didn't think it would fit without some modifications. If you've already ordered please document your install. This is my first choice for a tire carrier and I really hope it works!
Bowshock is offline
post #10 of 14 Old 02-15-2014, 04:08 AM Thread Starter
BobA
Thanks,will do. I can modify my rear supports on the rack if I need to.
01 TJ Sahara
77 DJ5
BobA is offline
post #11 of 14 Old 02-15-2014, 06:54 AM
Bowshock
I can't mod/fab my way out of a paper bag so I hope you can do a straight install.
Good luck!
Bowshock is offline
post #12 of 14 Old 02-23-2014, 03:08 PM Thread Starter
BobA
Cant post pic's on here, files are to big. Install went ok. Once I got tools lined up and had a couple glitches fixed the install went good. I'll try posting pic's on the JF facebook page.
01 TJ Sahara
77 DJ5
BobA is offline
post #13 of 14 Old 02-23-2014, 10:02 PM
Bowshock
Did you have to modify anything or was the install done fairly stock?
Bowshock is offline
post #14 of 14 Old 02-27-2014, 04:16 AM Thread Starter
BobA
I had to remove the garvin racks rear supports and brackets cause it interferes with the orfab brackets. Just need to fab and drill some new brakets to fix this. Everything else fit as it should. Hardest part of the job was removing tha factory torx bolts. Have to remove tailgate, hinges, right tail light, bolts for rear rollbar and canister thing behind taillight if you have one, to install. And drill about 10 holes.
I drove about 250 miles after the install and had no rattles so seems good to me. I put a few pics over on the jf facebook page. Was to wrapped up with the install to take "during" pics sorry.
01 TJ Sahara
77 DJ5
BobA is offline
