Opps!!! Think I Need New Finders.. Flat Fenders?
#1 | |
Ok so some how I got a small tree stuck in between my bumper and fender and well I will attached a pic.
So I was thinking about getting some Flat Fenders if that is the right name for them. Dose any one have an opinion if they are good bad? I do a fare amount of wheeling and the stock ones do rub a littler bit? Any one have some used ones? Do you think they will look good??? Or should I just fix it the stock way? ![]() ![]() ![]()
#2 |
Search the forum. But I do like my flat fenders, TnT 4.5" version, I hear the new version has all holes predrilled. It's a non-trivial install though. However, these are a full replacement, no need to cut stock fenders and retain stock inner fender liners.
Flat fenders allowed me to run 33x12.50s with no clearance issues and only a 1" BL. (Correct wheel offset of course) They tuck with less than 1/4" clearance at full flex, swaybar disconnected and RE superflex all around.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift 84 CJ7; frame off restoration in progress. The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice. |
#3 |
Definitely get some flat fenders, no reason to pay more for OEM replacements
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
