Okay, here is my list. What do you think? - JeepForum.com
post #1 of 16 Old 09-28-2009, 02:31 PM Thread Starter
MULIEFEVER
I plan on ordering tomorrow:
-RC 2.5" $300
-1" PA BL $90
-SRC Classic frotn bumper with D-rings by smitty built $159.99
-Classic rock crawler rear bumper with d-rings and tire carrier $349.99
$898.99 total, I plan on ordering from 4 wheel parts, they give 10% active duty discount.. But they don't have the Rough Country lift I am ordering it from another site I found today. They also give a military discount.
Thoughts?
MULIEFEVER is offline
post #2 of 16 Old 09-28-2009, 02:40 PM
2005X
-RC 2.5" $300
-1" PA BL $90
Thoughts?
looks like a nice setup, what tires you planning on running
2005X is offline
post #3 of 16 Old 09-28-2009, 02:50 PM Thread Starter
MULIEFEVER
Well, I am going to run the tires that came with my jeep through winter. They are a no name 31x10.50. and then in the spring I am going to buy a full set of rims and tires. Tires I am going to run General Grabber AT2's 33x12.50's , and for rims some outlaw II's
I have the At2's on my tacoma, Love them!!
post #4 of 16 Old 09-28-2009, 03:08 PM
2005X
do you know the backspace on the outlaw II. if the backspace is anything like "4.5 or "5 then your gonna run into rubbing issues while turning. if their 3.75 or "4 then looks like your setup is good to go
2005X is offline
post #5 of 16 Old 09-28-2009, 03:55 PM Thread Starter
MULIEFEVER
post #6 of 16 Old 09-28-2009, 04:01 PM
RogueSpear2023
If you call Rough Country and ask for Jeffery they will give you a 10% Discount if you mention you are a forum member, you should see if they will give you an active military discount too. I know when I ordered from the they gave me the 10% plus a good deal on shipping. I would order the body lift, 2.5" combo if I were you. You may also want to look at their motor mount lift too.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #7 of 16 Old 09-28-2009, 04:36 PM
RubiconRazorbac
RubiconRazorbac's Avatar
When I ordered they said the military discount is 10% but you can't double-up on the discounts. Could've changed since then though...
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #8 of 16 Old 09-28-2009, 05:32 PM Thread Starter
MULIEFEVER
I just realized they had the 2.5" and body lift combo! I will buy that.
Now, I have read that the MML is a waist of time and money. But, I have also read that it is a must. It seems to me that if it was so important, RC would iclude it in there kit. What are your thoughts? I obviously don't want any vibes, or issues.
post #9 of 16 Old 09-29-2009, 08:32 AM Thread Starter
MULIEFEVER
ANyone? Should I get the MML? I don't know!
post #10 of 16 Old 09-29-2009, 08:44 AM
1997_Sport
yes.
10 char.
1997_Sport is offline
post #11 of 16 Old 09-29-2009, 08:46 AM
TimeConsumer
Affirmative on the MML, IMO better safe than sorry. A MML will in theory correct the driveline issues that a SL created, coupled with a body lift. This way hopefully a transfer case drop can be avoided.
Sorry for the short "grey" answer, when I have a little more time ill explain the BL/MML in more detail... or just use the standard answer of "use the search"
Is it the dream that one day you might be something you're not?
TimeConsumer is offline
post #12 of 16 Old 09-29-2009, 09:24 AM Thread Starter
MULIEFEVER
Thanks! I searched. And I read a bunch of things.. A body lift does not change drive line angles. So for only a body lift it is not neccassary, correct? With the exception of the fan shroud? Now, I am installing the RC 2.5" lift, which could cause vibes. Maybe, maybe not.. So there is where the MML comes into play... Right? I really just want to do the best that I can do for my jeep.. It is my daily driver, so I want her to be taken care of! On the other hand, I don't want to spend money on something that I do not need...
post #13 of 16 Old 09-29-2009, 11:56 AM
TimeConsumer
Still learning the ins and outs of my jeep, and I believe we can relate currently with the build directions.
Anyway, yes the fan shroud is one reason for the MML. However it is also my understanding you want to add a 2.5" SL as well? This could bring the dreaded driveline vibes. Caused from lifting your jeep. Not necessarly from the Bl, but mostly the spring lift. To Cure said driveline vibes, options are:
Option A. install an SYE/CV (Unless you own a Rubicon, profile didn's say) then it would just be an CV. Starts out pretty expensive, goes from there, installed yourself...
Option B. lower your transfer case until the vibes disapear. IMO, why bring your jeep back down after fronting that cash to raise it in the first place?
And Option C. a MML.
I did say that your 2.5" COULD bring the vibes, but every jeep is the same. One course of action is using washers until your t-case is low enough to stop the vibes, and down the road purchase a MML if cash is tight now.
Hope it helps.
Edit: Just re-read my first post, meant to write SL, not BL.
post #14 of 16 Old 09-29-2009, 06:16 PM Thread Starter
MULIEFEVER
I got you! it's just some people claim they don't have any vibes at all. I think I will buy one just to be on the safe side. I ordered my lift today!
post #15 of 16 Old 09-29-2009, 06:28 PM
Imped
Imped's Avatar
Nice job on ordering good stuff. And it's good you got the MML. If you don't have ANY vibes, then don't install it and save it for the future. If you ever do a tummy tuck or lift anymore, you'll want it.
OlllllllO
IndyORV
Imped is offline
Wish list wickedoffroad YJ Wrangler Technical Forum 6 10-19-2009 09:51 PM
Christmas list/Wish list for a stock TJ BloodThirsty TJ Wrangler Technical Forum 16 11-07-2008 03:52 PM
MPG - List your rig and your MPG stunner Wrangler General Discussion 86 08-31-2008 07:27 PM
List of P/Ns JBWood05TJ TJ Wrangler Technical Forum 3 06-08-2008 12:18 PM
Christmas List..Price List JSBlu974X4 TJ Wrangler Technical Forum 4 12-06-2005 09:25 PM
