OB Air tank maintenance - JeepForum.com
post #1 of 7 Old 01-09-2014, 06:35 PM Thread Starter
xlTravislx
Just picked up a hornblasters train horn kit from a buddy. However, other than having a obnoxiously loud horn I'm just as excited about having onboard air.
The system It came with is a 150psi 2 gallon Viair 20005 model.
The system is mounted directly behind my driver seat. I know the pumps can be sensitive to the elements and driving a open air jeep 100% of the year (I don't own any form of a full top and jeep is my DD) can't be good.
I was thinking about making a plexi glass box for it with holes on the side. This way it will keep the rain and dust away. Dose this sound like a good idea?
Also, is it bad to keep the tank full all the time? Is it best to drain it out when not in use? & I believe this pump has a air filter that is removable and can be cleaned. How often should I do this?
-White Jeep Club Member 231-
Replacing random parts on hunches spurred from other vehicles and peoples experiences with them is the safest bet.
xlTravislx is offline
post #2 of 7 Old 01-10-2014, 03:24 PM Thread Starter
xlTravislx
bump
post #3 of 7 Old 01-14-2014, 12:58 PM
XTJake
ExtremeTerrain.com
XTJake's Avatar
That set up includes the 280C Compressor. According to Viair that compressor is moisture resistant but not water proof. Here is the installation/owners manual for that air source set up. You can see that it shouldn't come in contact with water. That being said I have my 400C mounted under the hood of my TJ by the firewall. It definitely gets wet when driven in the rain but does not get dunked under water in any situation and it has been fine under there.
If you're going to build a box just make sure it has plenty of ventilation as the compressor will get very hot when you're using it. Good Luck!
-Ryan
Jake R. |
Off-Road Outfitters
Toll Free: 800-988-4605 | Mon-Fri 10AM-6PM EST
Free Shipping on Orders Over $75!
PM me for our JeepForum Discount Code (must have 25 posts) or Price-Matching!
XTJake is offline
post #4 of 7 Old 01-28-2014, 09:28 AM
CropDr
you can leave the tank full, just put a petcock in the bottom so you can drain water out from time to time.
CropDr is offline
post #5 of 7 Old 01-31-2014, 11:23 AM
vadslram
Depending on the tank you should consider treating the inside.
When I built the OBA bumper tank I torched the whole thing until it was to hot to touch all over so I was sure it was dry then I got some etching primer and let it get sucked into the cooling tank. It sucked up almost a quart of the stuff. Then I rolled and tumbled the tank so it got all coated inside. I let it sit overnight then blew out the tank with dried air for a couple of hours. Then I used an old freon vacum pump to draw in thinned out plasti-dip. Did the same tumble and roll then blow down /dry out. That was years ago with a lot of open air compressing between then and now. Even today when I open up the drain on it I get clear water, not a hint of orange rust.
vadslram is offline
post #6 of 7 Old 02-04-2014, 06:35 PM Thread Starter
xlTravislx
how often should I drain my tank? there looks like a "petcock" on the bottom. Ive turned the compressor off and blew it to empty once or twice. If I do that on a normal basis (1se a week?) Should that help with keeping water out of the tank?
post #7 of 7 Old 02-04-2014, 06:57 PM
jjvw
jjvw's Avatar
Originally Posted by xlTravislx View Post
how often should I drain my tank?...
How often you drain the tank depends on how often the system is recharged and how humid the operating environment is. You should find out for yourself as it depends on your usage. A full air tank, sitting for days/weeks on end will not accumulate moisture.
Years ago, I ran an air compressor under heavy use inside a climate controlled room and often times would need to drain a gallon of water out every few days. Eventually, that same compressor was moved out into the dry Colorado air and I was lucky to get a cup of water out of it with similar use.
2003 Rubicon
jjvw is offline
