No dash lights,guages,radio.... - JeepForum.com
post #1 of 2 Old 06-14-2013, 11:01 AM Thread Starter
boomup73
Okay. We just picked up a 89 jeep. It has an issue though. The Guages on the dash are not working at all, except the speedo is working. No dash lights, no wipers and no turn signals or wipers. The hazards do work though. Checked the fuses and they appear to be good. Where should i start?
boomup73 is offline
post #2 of 2 Old 06-14-2013, 12:18 PM
Rproject
1987 YJ Wrangler
That's a whole bunch of unrelated items to have not working.
The gauge package, the right of the steering wheel (from the driver's perspective) has a circuit board which is prone to failure. Primarily due to water getting behind the dash. This may be your issue with some of your gauges.
Since your hazards work, you may simply have a bunch of bad bulbs in your dash that need changing.
One last gauge you haven't mentioned - the tach. Is that working?
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
