Newby Needs HELP.... - JeepForum.com
 2Likes
  • 1 Post By Kruzin
  • 1 Post By cranbiz
post #1 of 5 Old 09-19-2017, 11:38 AM Thread Starter
Donzo13
I just purchased my first ever Jeep. It is a 1990 Jeep wrangler YJ. 6 cyl engine, 5 speed. My question is..... under the hood and above the motor there is 2 long rods or bars that go from the front frame near the radiator back to the firewall. These rods/bars have threaded ends with a nut on them. What are these called? Where can I purchase one at? My jeep only has 1 and I want to purchase a 2nd one for the other side. Also, in the floorboard there is a hole maybe as big around as a coke can. I'm sure there is some type of plug, or cap that I can buy to place in this hole. (I think the hole is there to drain water from inside the jeep if it gets flooded) Where can I buy this plug/cap, Etc? And what are they called? ??? I am NOT a mechanically inclined person so please be patient with me. LOL Thanks for any help on this matter.
Donzo13 is offline
post #2 of 5 Old 09-19-2017, 12:08 PM
Kruzin
Kruzin's Avatar
2009 JK Wrangler
The rod is just a grille support rod. The original part# was 55050119, but they have been discontinued for years. I'd grab one from a salvage yard for 5 bux.
To plug the hole, you just need a body plug. Measure the hole and go to Napa, they have all sorts of generic body plugs in all sizes and shapes.
Donzo13 likes this.
'09 JK Rubicon
'01 XJ Sport
'10 Fusion
Kruzin is offline
post #3 of 5 Old 09-19-2017, 12:17 PM
cranbiz
The rod is called a support rod, part# 55050119. Good luck getting a new one as it's discontinued. Ebay has some used ones for about $25 a pair.
Floor Drain Plug, #55006578 Ormix-ada sells one thru Rock Auto for about $5 and Ebay has them too. I would check the size of the plug with a seller to make sure it's what you need.
Donzo13 likes this.
06 KJ
12 JK,2.5" Teraflex lift,Bilstein 5100's,BFG KO2's P305/65R17
17 WK2 Trailhawk
KN4BBA
cranbiz is offline
post #4 of 5 Old 09-20-2017, 08:39 AM Thread Starter
Donzo13
Thank you so much for the info. Awesome.
Donzo13 is offline
post #5 of 5 Old 09-20-2017, 12:20 PM Thread Starter
Donzo13
I appreciate the quick answers. I have ordered the Grill support rods and the drain plugs using your info. THANKS.
Donzo13 is offline
