New plugs tonight... - JeepForum.com
post #1 of 5 Old 06-21-2008, 06:51 PM Thread Starter
drew2000
drew2000's Avatar
Dropped in some new Autolite plugs, .035 gap. Just figured I would post to see what others are doing.
I like the new plugs, but darn I wish I hadn't lost my di-electric grease. Oh well, I guess I'll hit them with that when I check the distributor cap and rotor another time.
What are others doing this weekend?
Later,
Drew
1994 YJ - 2.5L, 2" BDS w/1" Shackles
2006 Dodge Charger R/T (5.7L Hemi)
drew2000 is offline
post #2 of 5 Old 06-21-2008, 06:58 PM
Brandon_YJ
1987 YJ Wrangler
Working tonight, then I'm off until Wednesday night.
Need to replace my tranny filter/gasket though, and do some wiring, and play with my carb a little more.
Oh, and I'm taking my 3yo mud bogging on Tuesday, that should be fun.
Maybe this should be moved to Wrangler General?
BTW, how well do those 33s fit on your rig? Do they rub any? Got your track or sway bars removed?
Originally Posted by Mean Max View Post
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using
in a (text only)
. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused
to see how I view the forum.
Brandon_YJ is offline
post #3 of 5 Old 06-21-2008, 07:05 PM Thread Starter
drew2000
drew2000's Avatar
They rub on the flares when flexed. I should have run a bigger lift. At the time I installed it I said "I'll never go bigger than 31's!"
So someday I'll either need a 1" BL, or new springs, or 31's
My front track bar and sway bar are still on, my rear track bar is off.
Drew
drew2000 is offline
post #4 of 5 Old 06-21-2008, 07:08 PM
Brandon_YJ
1987 YJ Wrangler
I was curious because you had 3" of lift and 33s.
My browser is setup to that it displays a users Jeep profile by default and yours just caught my eye.
You could probably get used TJ flares from ebay or criagslist for half the price of a 1" body lift, if your only issue is a little fender rub.
in a (text only)
post #5 of 5 Old 06-22-2008, 05:09 AM Thread Starter
drew2000
drew2000's Avatar
Yeah - I thought about the TJ flares but I don't want to cut up my body. My tub is in really good shape and I don't want to cut into it.
Later
Drew
drew2000 is offline
Need Spark Plugs - Can't find the Champion Truck Plugs #4412 2004JeepTJ TJ Wrangler Technical Forum 29 09-17-2011 08:37 PM
Need Help Tonight! roadking TJ Wrangler Technical Forum 14 02-19-2008 11:49 PM
Need help...TONIGHT 95YJRookie YJ Wrangler Technical Forum 8 05-16-2006 10:45 PM
Splitfire Plugs vs. Standard Plugs Alphadux TJ Wrangler Technical Forum 8 11-19-2003 06:35 PM
Look what I did tonight! iffar08 TJ Wrangler Technical Forum 14 05-28-2003 01:01 PM
