Need Side Mirrors for Doors off TODAY - JeepForum.com
post #1 of 11 Old 08-08-2012, 03:16 PM Thread Starter
explorerlyon
Poor planning on my part puts me leaving for the Rubicon Trail in the morning and wanting to remove my doors. I forgot about side mirrors. What can I find that would work TODAY? Meaning, it has to be available at a local Target, Walmart, truck stop, etc. Already tried the local 4WP and they are out.
I am driving the rig on the road, not just the trail, which is why I need the mirrors.
05 Rubicon Unlimited, Automatic
explorerlyon is offline
post #2 of 11 Old 08-08-2012, 04:05 PM
festerw
festerw's Avatar
HD, Lowe's, etc. grab 2 1 foot 3/8 threaded rod, 8 washers and nuts to fit, 2 cheap mirrors with brackets.
Put the rod in the top door hinge and bend to the desired angle, nuts and washers on the hinges and to hold the mirror bracket on.
Not pretty and could be more stable but it'll work.
Hers - 2011 Dodge Durango Crew
Mine - 2003 Jeep Wrangler X
1998 Jeep Cherokee Classic
festerw is offline
post #3 of 11 Old 08-08-2012, 04:14 PM
Marauder_Pilot
Marauder_Pilot's Avatar
Go to your local motorcycle shop and get two generic mirrors. They'll come on some sort of clamp bracket. Chop that off, attach it to a piece of threaded rod, put two nuts on it (One above and one below the hinge) to clam it in place, and you're set.
EDIT: If that Jeep in your av is yours and current, you might even be able to clamp them somewhere on your hinge lights.
"Buying a Jeep for on-road handling is like downloading porn to savor the cinematography."
-TTAC
2000 Jeep Wrangler TJ Sport-OME HD Lift, ProComp bumper, 32" BFG TA K/Os
2010 Kawasaki KLR650-Stock
2006 Ford F-250-Stock
Marauder_Pilot is offline
post #4 of 11 Old 08-09-2012, 06:20 AM
thrown_hammer
This. Autozone $5. It stays on with or without doors.
thrown_hammer is offline
post #5 of 11 Old 08-09-2012, 06:49 AM
IrishSkittlez
That counts as a side mirror? That's kinda cool. My friend did the first option and it works pretty well, costs about $12 give or take depends on where you go.
"Courage is being scared to death, but saddling up anyways." -John Wayne
Mudding, because all other sports only require 1 ball
Owner and founder of "Unexpected" 4x4 Club
All Girls Jeep Club #313 Blue Jeep Club #383
IrishSkittlez is offline
post #6 of 11 Old 08-09-2012, 07:02 AM
thrown_hammer
Never been hassled about it. Probably depends on location. Here in indiana I could probably drive around with out any mirrors and never hear anything... Its a good temporary get me home and find a more permanent solution if nothing else. :-)
post #7 of 11 Old 08-09-2012, 10:31 AM
roadyrob
1987 YJ Wrangler
on a yj harley mirrors go in the hinges, not sure about newer jeeps tho.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #8 of 11 Old 08-09-2012, 10:35 AM
fang_x
The cheapest alternative is to go to walmart, or any bike shop, and buy two elcheapo bike mirrors, they are like ~5$ each. remove the clamp and bolt it into the hinge hole. Its already threaded and simply just tighten with vice grips and your set.
Ive been running mine for two summers, they are still doing their job perfectly. I prefer them over stock actually.
You could also go to a motorcycle shop and get a motorcycle mirror but those your gona be paying more.
'98 TJ Manual -2.5" rcx long arm on 31
'99 Xj, Stock on 30"
'86 Monte Carlo 357 stroker. 450hp.
fang_x is offline
post #9 of 11 Old 08-09-2012, 11:10 AM
Dragonwitch
LOL....we have several motorcycles around and just poked mirrors into the door bracket and zip-tied them on....they wobble a bit but it works for temp job.
Dragonwitch is offline
post #10 of 11 Old 08-09-2012, 11:44 AM
frenchy206
Easiest, is to just not worry about it. If you do get pulled over, just say that your doors were stolen. Problem solved.
03 TJ Rubicon
frenchy206 is offline
post #11 of 11 Old 08-09-2012, 01:27 PM
IrishSkittlez
I'm sure they might not bother me in jersey but I'll try something
Do i need Side Mirrors with doors off? Dkrep YJ Wrangler Technical Forum 19 06-20-2012 04:45 PM
Doors off, Side Mirrors.. drvnwheel JK Wrangler Technical Forum 3 05-11-2010 08:22 AM
Side Mirrors w/ Doors Off? reoterq TJ Wrangler Technical Forum 6 06-09-2006 04:29 PM
Side Mirrors withour doors DetroitDoorless TJ Wrangler Technical Forum 21 05-27-2005 11:38 AM
where to get side mirrors for when doors r off Jeepthang04 TJ Wrangler Technical Forum 46 03-30-2005 12:13 PM
