12-03-2009, 02:25 AM
#1
I cant find one with a wide enough opening for our jeeps for a reasonable price.
I basically need a 10 dollar cheapo one time use one. Not one of the nice like 70 dollar ones.
12-03-2009, 04:58 AM
#2
I got mine from autozone parts. was like 25 bucks
AMSOIL DEALER
Reason: i am a moron and put wrong parts store in
12-03-2009, 06:37 AM
#3
Some autopart stores rent them out. Don't know if they will work 100%, but when it is free its worth looking into. I have rented tools from autozone a couple times, broke one and still got my deposit back.
12-03-2009, 11:28 PM
#4
Only have a napa and jerrys around here.
Ill check out both though I guess.
12-04-2009, 10:57 AM
#5
How about this one? I used the on linked below, plus a torch, freeze spray, PB Blaster and then had to cut it to get mine to move what a pita for a Jeep with no rust.
- Harbor Freight Tools - Quality Tools at the Lowest Prices
12-04-2009, 11:06 AM
#6
I've rented one from autozone. Maybe napa or jerrys has a similar service
Jeep: 1999 Black TJ Sahara, 6-cylinder, 4.0L, front dana 30, rear dana 44, 3.73 gears, 3" Teraflex, 15x8 Eagle Alloys, 33x12.50R15 Mickey Thompson MTZ, Bestop Sailcloth top, KC 150w Daylighters, KC 55w fogs, CB radio, 73k miles
Daily Driver: '05 Silver Civic EX Coupe, 4 cyl 5-speed Manual, ~35 MPG, 54k miles
12-05-2009, 12:03 AM
#7
She's my density...
I got one at autozone for like 10-20 dollars. They had a 90 dollar one but I just picked up the cheap one next to it. I busted the first one. I took it back and they replaced it no questions asked. With the second one I used it in conjunction with a BFH and it popped right off. The one I bought looked just like the HF one in the link above.
M.F. Leans
93' YJ 4.0L AX-15, 4" Pro Comp lift, 3/4" shackles, 1" BL, 33x12.5x15 BGF MT's, and some other stuff
Originally Posted by Mike Jones
Catch me on the highway or about to tear the mall up.
12-05-2009, 02:40 AM
#8
I am fairly certin that HF one is too small
I have one that looks exactly like that, and it will not fit.
12-05-2009, 03:15 AM
#9
Around here (NC) Advance Auto has used ones in a kit, they sell it to you and when your done the next day/week, you return it and get all your money back. Basically a rental. They had a nice kit when I did mine - $90. Just look inside it before you get it to make sure all the parts are in it. If you want to keep it...that's ok too.
This forum requires that you wait 60 seconds between searches. Please try again in 1 seconds.
12-05-2009, 08:13 AM
#10
Just use some heat and a MFBAH.
-Mike
No jeep but I do have a 04.5 Cummins with a 4in exhaust, edge j/a, and I guess thats it....for now
12-05-2009, 08:16 AM
#11
Bought mine at Napa. It was not one of the cheap ones though. I do not remember it being outragous in price.
http://www.napaonline.com/Search/Res...word&Nty=1&N=0
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
12-05-2009, 11:18 AM
#12
Ya and run the risk of bending the shaft. Might be okay if he is replacing the gear box. But they invented the puller for a reason.
To the OP. When you get a puller. you will need to install the puller after you remove the nut. Put some pressure on it and while there is pressure on the pullerpulling down on the arm take a hammer and hit the arm that is around the shaft. a few decent whacks and the pitman arm should pop free. Dont hit to hard or you could risk bending the shaft.
AMSOIL DEALER
12-05-2009, 03:39 PM
#13
i rented the one from autozone, they had a big one and a small one. the big one fit mine. i wound up rounding off the puller, so i ground it down to the next sive down, and it popped off. but did use heat, pd and tried to cut it off.
^^^thats a lie.
12-05-2009, 04:08 PM
#14
I pulled mine with a free rental from the auto parts store. I also brought it back broken, but since the brand was one of those 100% guaranteed brands they didn't say anything.
1995 YJ 2.5 - 4” RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
My build thread...
I've got a shotgun, a rifle and a four wheel drive...
12-05-2009, 09:19 PM
#15
If you are replacing it, why not just cut it off. I have never been able to get one of those off without spending alot of time on it. That was until I discovered an angle grinder....lol
