My JK tow less than a Mini Cooper - Page 4 - JeepForum.com
post #46 of 55 Old 03-28-2013, 01:38 PM
cyberpyrot
Originally Posted by fchabot View Post
Does anybody know where I could find a european version on the wrangler owner manuel, or any towing capacities in europe?
Juste to compare.
it will tow 1,000 Royals Sorry couldn't resist.
I have attention defiiiii hey is that a rabbit?
Thought of the day
Trust people who like big butts they cannot lie...
cyberpyrot is offline
post #47 of 55 Old 03-28-2013, 03:05 PM
frenchy206
4,000 Royals
03 TJ Rubicon
frenchy206 is offline
post #48 of 55 Old 03-28-2013, 05:39 PM
LimeLJ
LimeLJ's Avatar
About 5,500 pounds with a LJ.
I later replaced the transmission due to clutch pack failure.
LimeLJ is offline
post #49 of 55 Old 03-29-2013, 06:42 AM
32vld
Originally Posted by 2jhanna View Post
I tend to agree, (and I haven't done the math) if you don't use OD (manual or auto) the net gearing should be close to 3.73.
32vid- your `05 LJ should have 3.73 gears.
Factory ordered with 3.42 for mileage and lower rpm for quieter engine.
Checked owners manual all rears are rated for 3,500 lbs.
32vld is offline
post #50 of 55 Old 03-29-2013, 06:51 AM
32vld
So that means that if I leave it in 5th gear that would give me a 3.82 rear axle gearing, then I would be ok to tow more?
What could happen if I tow about 1600lbs on a 1000lbs ridiculous max capacity?
Leaving it in 5 th does not allow you to tow more.
Leaving it in 5th will prevent one from lugging the power train when towing 3,500 lbs with a lower rear ration such as a 3.07 or 3.23.
32vld is offline
post #51 of 55 Old 03-29-2013, 07:02 AM
32vld
I read on JF years ago from an Englishman that TJ's were rated to tow 5,000 lbs over there.
My 2005 TJU and the Cherokees are both full frame both came with a 4.0 and similar in length.
Cherokee is rated to tow 5,000 lbs.
A wrangler TJU or 4dr JK mechanically handle 5000 lbs.
Cherokee has an enclosed body. This why the jeep bean counters and jeep lawyers determined to down rate the unlimiteds.
32vld is offline
post #52 of 55 Old 05-08-2013, 01:22 PM
JasonVideo
Late to the party
Hi everyone. I see this thread is pretty dead but I'll ask here anyway. I just bought a used '13 Rubi Unlimited w/ auto-tranny. It has the tow package, so I'm assuming 4.10 gears. I'm on the stock BFG MT's. I want to go to 33 AT's. So will I be able to tow a 3500 pound camper? I'm guessing trailer brakes and a swaybar will be important for mountain driving. I'm planning on driving to next year's Easter Jeep Safari in Utah. I'm in Florida. A small camper would make life a lot better on a 5000 mile trip! I'm thinking something like one of these:
http://www.yourrvconnection.com/quic...=150&model=494
http://www.cruiserrv.com/fun-finder-...fications.html
Any thoughts?
Thanks,
Jason
JasonVideo is offline
post #53 of 55 Old 05-08-2013, 01:54 PM
bogleparsons
sexy Rubi!
yes you'll be fine to tow a small camper.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #54 of 55 Old 05-09-2013, 06:40 AM
LimeLJ
LimeLJ's Avatar
Trailer brakes are just always nice to have towing over 1,000 pounds.
LimeLJ is offline
post #55 of 55 Old 05-12-2013, 07:45 AM
rondak46
Finally I think I'll just do it, keeping in mind that limitation while driving
It's all about swerving in an emergency. If you over-swerve in an emergency, the short wheelbase is more likely than the long wheel base to give the trailer an advantage on your *** end; allowing the jeep to be flipped on its side,
rondak46 is offline
