Mods I've done so far *pics* - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > Wrangler General Discussion > Mods I've done so far *pics*
The Original 3/8" Ruffstuff Diff Cover!The Cure for your Tie Rod Roll!1976-1986 Jeep CJ7 with Stationary Vent Windows Weatherstr
Unread 11-02-2009, 04:45 PM   #61
oj707
cute jeep dude.
oj707 is offline   Reply With Quote Quick reply to this message
Unread 11-06-2009, 02:43 PM   #62
Hesher420
Well, I installed my Rock Krawler Adjustable lower control arms in the rear of the Jeep today. With the 2.25"BB and the Rokmen TT my yoke and pinion angles are at 6* and the driveshaft is at 15*. I do have a bit of a vibe now between 50 and 55 mph so I'll have to play with it some more to cure that. Also, I have to mess with the t-case linkage because it is binding on the pivot that mounts to the body, so I cannot shift into 4L right now.
thanks sportcoupe for the great deal on the arms!
**'06 Blacked Out LJ**
> > > LJ Owners Group < < <
Black Jeep Society
"We are one. One society. Digitless."
"I am not a number, I am a free man!"
Hesher420 is offline   Reply With Quote Quick reply to this message
Unread 11-09-2009, 06:55 AM   #63
Hesher420
Managed to fix the vibe today by playing with the lengths of the LCA's. I rotated the axle forward a bit and have the angles set at:
Yoke: 6*
Axle: 13.5*
Pinion: 7.5*
I know that without a SYE, the Yoke and Pinion angles should be the same, parallel. All I know is, when they were parallel, I had vibes, now I do not.
Black Jeep Society
Unread 11-09-2009, 07:05 AM   #64
ZeroGravity
It just means your D35 is going to explode like the toothpicks it's made from
Good to hear you got that worked out.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline   Reply With Quote Quick reply to this message
Unread 11-09-2009, 04:13 PM   #65
Hesher420
Excuse me sir, It is no lowly 35! Its a Dana 44.
Black Jeep Society
Unread 11-13-2009, 07:39 AM   #66
Hesher420
Received the solution to my t-case linkage today. (hopefully)
Bracket from Advanced Adapters
And, the modifications I'll be making due to my belly up skid and thanks to Alexia's experience.
Black Jeep Society
Unread 11-13-2009, 07:52 AM   #67
1ATony
Vendor
That's a great looking Jeep.
CLICK HERE^^^ TO SAVE ON JEEP PRODUCT ORDERS IN APRIL!
Facebook|YouTube|#1AAUTO ON INSTAGRAM
1ATony is offline   Reply With Quote Quick reply to this message
Unread 11-13-2009, 10:21 AM   #68
Mud-Hunter
Bad *** Jeep! You should some how put "Reign In Mud" under the Slayer name! Nice Work!
Mud-Hunter is offline   Reply With Quote Quick reply to this message
Unread 11-13-2009, 06:02 PM   #69
-Rudy-
-Rudy-'s Avatar
2003 WJ
Any pics of it with BL, etc? I have a 3" lift on mine and have been kicking around different tire ideas.
-Rudy- is online now   Reply With Quote Quick reply to this message
Unread 11-14-2009, 08:46 PM   #70
Hesher420
(overall 3.5" lift on 31" tires)
Black Jeep Society
Unread 11-14-2009, 11:22 PM   #71
4biY
Originally Posted by oj707 View Post
cute jeep dude.
Dude he called your Jeep "cute" LoL
Anyways a tru blackout would be tinted headlight covers and all your marker/turn sig lights blacked out also> BadA$$ TJ man!
4biY is offline   Reply With Quote Quick reply to this message
Unread 11-14-2009, 11:56 PM   #72
-Rudy-
-Rudy-'s Avatar
2003 WJ
Originally Posted by Hesher420 View Post
I can get a better pic tomorrow, but heres one for now...
Looks nice.
Unread 11-22-2009, 04:15 PM   #73
Hesher420
Added a sticker to the tire cover today. From the Slayer album "Reign In Blood"
The sticker is a real heavy duty Vinyl! Not the cheap thin, flimsy vinyl type, made by Xtremjeep for a very reasonable cost!
Black Jeep Society
Unread 11-25-2009, 09:23 PM   #74
Alexia
I had completely forgotten I even sent that mount to you! Glad to see it worked out so well. That is a lot of skid plates too.
Little extra help with the transfer case linkage and to hopefully avoid needing to pull it back out again. I found that the rod for the crank was too long and rubbed the rubber bearing cover against the tub. I ditched the little piece of rubber and cut the rod down to just a few millimeters sticking out of the bearing. I can take a picture later if you are unsure of what I mean.
2004 Jeep Wrangler Unlimited, Automatic
RC 2.5" Lift - RC 2.5" Rear Track Bar Bracket - JKS 1.25" Body Lift - JKS Front Disconnects - JKS 1" Budget Motor Mount Lift - Spidertrax 1.25" Spacers -
Power Door Locks with Keyless Entry
Build Project Thread
Rocker Guard Comparison Chart - Final Differential Gear Ratios - Oxygen Sensor FAQ
Alexia is offline   Reply With Quote Quick reply to this message
Unread 11-26-2009, 10:05 AM   #75
Hesher420
o.k. , now I know what you mean, thanks for the heads up.
Black Jeep Society
