Mods I've done so far *pics* - Page 4 - JeepForum.com
post #46 of 113 Old 08-30-2009, 08:14 PM
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
Looks good man... I am probably going to raptor my grill also when I do the tub... I think the black on silver will look HOT.
-Dave
AustinCJer is offline
post #47 of 113 Old 09-27-2009, 04:56 PM Thread Starter
Hesher420
Well, I have one more step finished, the skid plates are all painted. Now they are just sitting around waiting for me to have time to install them
A few pics of Rokmen's skids...
The whole kit...
The engine skid...
The bracketry for the engine skid...
The TT...
The gas tank skid...
A few of the beautiful welds...
"We are one. One society. Digitless."
"I am not a number, I am a free man!"
Hesher420 is offline
post #48 of 113 Old 09-27-2009, 05:05 PM Thread Starter
Hesher420
I cleaned the skids, roughed them up with a 60 grit sanding disc, cleaned once again, used a metal etch on them, rinsed, and dried.
Then came 2 coats of the POR 15 to seal them up!
Oh, and one more thing,
When installing the TT, Dave at Rokmen said to cut 5/8" out of the hanger and weld the bracket back together. This will keep the exhaust pipe from contacting the control arm mounts.
I found someone on JF that had installed a Nth Degree skid recently and purchased her stock exhaust hanger. (The Nth comes with a new exhaust hanger, the Rokmen does not.) Having this part ready to go at its new shorter height will eliminate a step during install later.
post #49 of 113 Old 10-20-2009, 07:10 PM
CMEvans79
Looks real good ... I have been wanting to black out my grille since before I had it when I was driving our Liberty ... now that I have a TJ, it Will be blacked out. I noticed your zip ties are white ... isn't that a no no for the Black Jeep Club?
They say your jeep will eventually earn itself a name... Mine has now done that... ladys and gents, meet "Strife" because lately, that's all its given me.
CMEvans79 is offline
post #50 of 113 Old 10-20-2009, 08:23 PM Thread Starter
Hesher420
I had not noticed that myself.
Now thats just lazy, I have black zip ties in the basement!
I'll have to change them out some day.
post #51 of 113 Old 10-20-2009, 08:46 PM
CMEvans79
Glad I could help
post #52 of 113 Old 10-21-2009, 07:56 AM
MULIEFEVER
I was wondering something? When you used the Herculiner product on your jeep did you add the UV protector? I have used herculiner in the past and it workes awesome! But I hated the fact that it fades really bad like 1 year later! Just curious. You have a kick *** jeep by the way!
MULIEFEVER is offline
post #53 of 113 Old 10-21-2009, 02:19 PM Thread Starter
Hesher420
^Thanx
I did not use the UV protector because I like the flat black look actually.
The interior, even though the Heep is topless all summer is still shiny-like-new.
The exterior stuff is all quite nicely faded!
(Maybe took about 2 months only)
post #54 of 113 Old 10-22-2009, 06:56 AM
MULIEFEVER
I see, thanks, LOVE IT!
post #55 of 113 Old 10-22-2009, 04:50 PM Thread Starter
Hesher420
I installed the new gas tank skid a few days ago, gained an inch of ground clearance. Then I put the hard top on and the back seat in today, and yup, lost my extra inch, at least for the winter.
A few pics, using the exhaust pipe as a height reference...
(If you look real close, you can see the Rokmen skid's dimple just below the pipe in the second pic.
post #56 of 113 Old 10-28-2009, 03:56 PM Thread Starter
Hesher420
Installed the T-case and Engine skid yesterday.
The install went incredibly smooth! I removed the stock transmission skid, just 2 bolts holding it to the frame up front and 2 bolts holding it to the t-case skid in back. Then I removed the transmission mount nuts, used a floor jack to support the transmission bell housing, placed a second jack under the t-case skid, loosened the 6 bolts holding the skid up until it was resting on the jack, then completely removed the 6 bolts, lowered the skid, and pulled it out.
I then removed the transmission mount/exhaust hanger assembly and replaced it with one I bought from JF member Alexia. (Thanks!) I had previously cut 5/8" height from the exhaust hanger bracket and welded the two pieces together. Shortening this bracket was strongly recommended by Dave @ Rokmen to keep the pipe from hitting the upper CA on the passengers side. Worked great as the pics will show!
The rest of the install was pretty straight forward, roll the t-case skid under the Jeep, jack it up, bolt it on, and reinstall the transmission mount nuts. As I do not have the money to purchase Adj. LCA's at this point, I installed a homemade 1" T-case drop at this time. I did not drive it to see if I had vibes before installing, but would like to get all the right parts before I remove the drop.
Onto the engine skid plate. I snugly (but not tight) installed the mounting brackets the the bottom of the motor mounts and hung the mounting bars from them. Then I rolled in the skid plate with a floor jack and raised it into place so the rear mounting holes (to the t-case skid) lined up and put them in, then the front mounting bolts to the support bars, snugly also. Now that everything was lined up I went back and tightened all the bolts.
Even w/ the drop, still 1.25" more clearance than stock, and much heavier duty!
Skids line up flat, above the height of the front axle tube.
Front mounting arms.
Lots of clearance between the exhaust pipe and the UCA mount.
post #57 of 113 Old 10-28-2009, 04:38 PM
dwilliamsceg
The whole kit...
The engine skid...
The TT...
Are those welds machine or done by hand? Either way they are beautiful.
Good write up. I am enjoying it.
D.
dwilliamsceg is offline
post #58 of 113 Old 10-29-2009, 10:52 AM
rezamesa
looks sweet, maybe get rid of that wheel cover tho.... hehehehe
rezamesa is offline
post #59 of 113 Old 10-29-2009, 11:03 AM Thread Starter
Hesher420
That wheel cover serves 2 purposes.
1. Slayer IS F'ing Metal!
2. It hides the fact that I still have a 30" spare on the Jeep "Canyon" rim.
post #60 of 113 Old 10-29-2009, 12:05 PM
Barrio
Slayer!!!!
-OD Green/Flat Black 92' 4" Rough Country Lift, tons of crap.
-Rio Red 1995 Ford Mustang- Daily Driver
Originally Posted by alfmoney
i see theres a bunch of toughguys on this forum or internet gangstas
Barrio is offline
Mods and Pics Douglas S. YJ Wrangler Technical Forum 16 04-20-2008 08:26 PM
Pics Of My New JK with Mods fer328 JK Wrangler Technical Forum 52 07-31-2007 02:24 PM
New Pics of my completed mods BIGDADDYCASEY JK Wrangler Technical Forum 27 03-26-2007 07:26 AM
Mods and Pics. Appstate19 JK Wrangler Technical Forum 1 10-15-2006 09:48 PM
New Mods w/Pics bondo303 TJ Wrangler Technical Forum 17 07-23-2004 12:53 PM
