Mixing Gears? - JeepForum.com
post #1 of 7 Old 10-20-2013, 10:52 AM Thread Starter
Dake
Dake's Avatar
Mixing Gears?
My buddy ordered gears for his TJ. He wanted 4:10s they sent him 4:11 for the rear and 4:10s for the front. They told him this will be Ok. I think they need to match? What do you think?
Waiting on my Rough Country lift to sag!
Dake is offline
post #2 of 7 Old 10-20-2013, 10:59 AM
biffgnar
biffgnar's Avatar
That will be perfectly fine. Very common for there to be a small difference based on how gears have to be machined to fit a particular axle. IIRC a general guide you hear thrown about is being within 1-2%. 4.10 to 4.11 is only 0.25 of a percent. Personally, I've run 0.5 of a percent difference and had no troubles.
biffgnar is offline
post #3 of 7 Old 10-20-2013, 11:40 AM
bpounds
bpounds's Avatar
^ Correct.
I had a Ford truck that came from the factory with 4:10 and 4:11. You couldn't tell it without looking at the specs.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #4 of 7 Old 10-20-2013, 11:51 AM
Jonny Jeep
Jonny Jeep's Avatar
It's perfectly fine. The difference is due to the amount of teeth that are on the ring and pinion gears.4.10s have 41 ring gear teeth and 10 pinion teeth. 4.11s have 37 ring gear teeth and 9 pinion teeth. You'd get more difference with having tyres that are slightly more worn on one axle.
Jonny Jeep is offline
post #5 of 7 Old 10-21-2013, 12:32 PM
ridesno4llfe
Just to add my knowledge on this. Its off .01 because the fronts have to turn. This allows them to compensate for the difference in speed front to rear letting the front turn a little faster
Everytime I sell a jeep I say no more then a new one shows up in my driveway
ridesno4llfe is offline
post #6 of 7 Old 10-21-2013, 01:48 PM
biffgnar
biffgnar's Avatar
Running them exactly the same works just fine. .01 (and even a bit more difference) just doesn't make a difference. As previously posted the exact number just falls out from what gear sets will fit in what housing.
biffgnar is offline
post #7 of 7 Old 10-22-2013, 01:02 AM
carnuck
1984 J-Series Truck
It does actually work better unless you have a tcase that allows changes (like a NV242 in 4 hi open) Locked cases will push the front around the corner otherwise.
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
