Made it through floodwater, but... - Page 2 - JeepForum.com
post #16 of 17 Old 05-05-2013, 07:57 PM
COLOUXJ
2010 JK Wrangler
Originally Posted by 222Doc View Post
If its a stock Jk there are no zirks. Makes that fix ezpz. They rest of the suspension is all replace when worn out. water may speed up that. If replaced with better parts they will have zirks. Then you can go crazy with the grease gun.
Good thing it did not hydro lock. hard to believe it did not.
When you ford water correctly you actually create an air pocket in the engine compartment, the water going over the hood a little bit is no big deal. If he had stopped it would have caused problems. IIRC jeep rated the wrangler to ford 3 feet or so of water?
COLOUXJ is offline
post #17 of 17 Old 05-06-2013, 12:11 PM
j_bydesign
Wrench Wheel Repeat
j_bydesign's Avatar
I think what most people are trying to say is that you should check all of your fluids(if they look milky then you need to take some serious action... as your vents were most likely under water... without a snorkle that was not the smartest move... down in South Florida we have some serious water hazards... most relocate vents and install snorkles, silcone up elec. connections... the biggest hazrd you managed to avoid is the cr^p that was under the water! consider yourself pretty lucky. you clip a fire hydrant or something similar and your gunna do some serious damage...
not to mention how those fans love to flex and take out your rad!
'04 TJ(wheeler) '65 CJ5(sold :( )...'05 LJ(Scrambler conversion) 89' Int. Harvester Toter (get the TJ to and from)! '80 CJ7 Resto Mod(sold) 1985 CJ7 Renegade (in process)
j_bydesign is offline
