Made it through floodwater, but... - JeepForum.com
post #1 of 17 Old 04-18-2013, 03:45 PM Thread Starter
joeranger
I had to "rescue" my wife who was stuck at a hotel behind rising flood waters here in Chicago.
I drove my 2008 4dr Sahara through 3.5ft of river water for about 100 yds. Water was splashing up over the hood, but it made it back and forth fine.
Back at home, I used a leaf blower to try to dry out the engine. The hood itself filled with water which took a while to drain.
Now one of my after market lights just stays on. I disconnected it to keep the battery from draining until I rewire it.
What else should I do to prevent water damage? Oil change? Fuel additive? Grease?
joeranger is offline
post #2 of 17 Old 04-18-2013, 05:47 PM
NonRubicon
I would change the engine oil, transmission, t-case fluid, differentials. Might as well grease up any zerk fittings you have while you are doing the maintenance.
NonRubicon is offline
post #3 of 17 Old 04-18-2013, 05:52 PM
Ripper3494
there are some fuel additives sold at autozone as well as an additive for an auto transmission to help get water out. i use both of those if i go to deep. i was in the same boat (haha) today driving around the flooded areas. i drove past a completely submerged civic...
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #4 of 17 Old 04-18-2013, 06:38 PM
222Doc
222Doc's Avatar
If its a stock Jk there are no zirks. Makes that fix ezpz. They rest of the suspension is all replace when worn out. water may speed up that. If replaced with better parts they will have zirks. Then you can go crazy with the grease gun.
Good thing it did not hydro lock. hard to believe it did not.
222Doc is offline
post #5 of 17 Old 04-18-2013, 06:47 PM
Ripper3494
I was surprised as well. I only took mine deep enough to touch the bottom edge of my hood and i called it quits lol
build thread:
RC vs BDS
post #6 of 17 Old 04-18-2013, 08:00 PM
222Doc
222Doc's Avatar
at some point I think I would have had her swim.
222Doc is offline
post #7 of 17 Old 04-18-2013, 08:27 PM
ncb
Do you have a snorkel?
ncb is offline
post #8 of 17 Old 04-18-2013, 08:46 PM
metaljeep
I heard chicago was flooded, but I didn't think it was that bad over there. I'm only 60 miles from there. I guess it could flood I mean what only two days of sunshine in the last two weeks and rain the rest.
metaljeep is offline
post #9 of 17 Old 04-18-2013, 09:18 PM
solarpower
You should move faster....the grill will push that water away instead of letting it wash on your hood and over your intake.
if it stalls you need to be able to hoist your top into a sail pretty fast because water really likes to seep into sitting objects.
04 TJ "U" package
06 XK Commaddy 4.7
solarpower is offline
post #10 of 17 Old 04-23-2013, 07:31 PM
Trespasser
Judging from that (awesome) picture, that was an extremely risky trip. Hood-level deep = intake level deep. Unless you have a snorkel, you're very lucky that you made it.
Trespasser is offline
post #11 of 17 Old 04-24-2013, 07:31 AM
Imped
Imped's Avatar
Had a local guy try something similar.....his body was found Sunday I believe. Good job gettin it done.
OlllllllO
IndyORV
Imped is offline
post #12 of 17 Old 04-24-2013, 09:21 AM
222Doc
222Doc's Avatar
last year in July we has one of those 100 years rains here, we get at the most a few inches a year. This storm had like 4 inches in a few hours. A guy in a Harley thought he could " make it". They found his body a mile down the wash.
222Doc is offline
post #13 of 17 Old 04-26-2013, 02:44 AM
DipCope
http://www.youtube.com/watch?v=MINoPet6E7A
I remember that very well haha
DipCope is offline
post #14 of 17 Old 05-03-2013, 12:28 PM
gcan
Glad you made it through, sounds like you got the water out asap! I went thru a puddle shorter than that and hydrolocked my 08, and there's apparently only one way outa THAT jam. so glad to hear someone with a happy ending!
gcan is offline
post #15 of 17 Old 05-03-2013, 02:33 PM
Evian
Replace the engine, transmission, PCM, transfer case and wet seats! Just kidding. Drain everything out and replace with new fluids. I was around there two days after the storm. I was trying to get to Ikea in Schaumburg. I was taking Golf Road to get to Schaumburg. I was forced back. I ended up the highway. The water levels were really high. I wouldn't have done what you did in a unmodified Jeep. If one of those on board computers would have gotten wet your Jeep would be toast now. You are one lucky dude.
Evian is offline
