Low tire pressure sensor going off - JeepForum.com
post #1 of 12 Old 07-01-2012, 12:34 AM Thread Starter
millav
Hey
I have a 2011 wrangler and the low tires pressure light has been going off since month 1. My dealership garage says they've replaced all of the sensors, but it still goes off...anyone else have this issue?
Thanks!
Milla
millav is offline
post #2 of 12 Old 07-01-2012, 01:29 AM
1222
RIP John
1222's Avatar
to the forum.
What psi are putting in your tires and are you doing the same to the spare tie?
1222 is offline
post #3 of 12 Old 07-02-2012, 05:25 PM
cphilip
2010 JK Wrangler
Another government mandate for your safety.... sigh...
cphilip is offline
post #4 of 12 Old 07-02-2012, 07:50 PM
jeepjerryp7m8
1982 CJ8
Welcome!
Buy a YJ or TJ and never worry about this again.
Seriously though, try rotating your tires front to rear. The pressure sensor really reads RPM, not pressure, if the problem goes away tell the dealer what you did. That will help them track it down.
Jerry
BTW; Are your tires the same size?
jeepjerryp7m8 is offline
post #5 of 12 Old 07-02-2012, 10:57 PM
squarelight94
Originally Posted by jeepjerryp7m8
Welcome!
Really?! How does it work like that? (I don't know too much about the tpms' but I really thought it sensed pressure
OP just wait till you air down and have the sensor beeping at you the whole time on a trail! Haha thats how my buddy found out about this problem.... It was hilarious
http://madhatters4x4.com
squarelight94 is offline
post #6 of 12 Old 07-03-2012, 12:37 AM
SRT8LAREDO420
My 07 Laredo and my 08 srt8 both have restarted tpms sensors ever since I bought the jeeps they have had issues. I just recently decided to switch all tpms sensor to the new style sensor made by vdo. (aluminum valve stems) when I replaced them all I had to do was disconnect the iod fuze located under the hood #27 reconnected after 10 min and the wcm will clear any past codes. Have psi at 36 havnt had a problem with my system for 300 miles. Keep in mind jeep do not have a set procedure for resetting the tpms sensors besides just driving the car for 10 min above 20 mph. The premium tpms systems require a magnet to wake the sensors up. Hope this helps.
SRT8LAREDO420 is offline
post #7 of 12 Old 07-03-2012, 06:21 AM
Ruffles
2010 JK Wrangler
If you haven't done so already, check the pressure on the spare.
Ruffles is offline
post #8 of 12 Old 07-03-2012, 09:50 AM
TempVAJeep
Can't see how the RPM's come into play, Ones on my Subaru will come on the first cold spell of the fall because the temperature has reduced the pressure in the tires...
LOL, My coworker just told me about his brother doing the same thing, aired down for beach riding & couldn't figure out the alarm going off... thanks US Gov't!
TempVAJeep is offline
post #9 of 12 Old 07-03-2012, 10:29 AM
Burlbook48
Burlbook48's Avatar
Another frigging computer tool to replace common sense. (sigh...)
Pity the .gov can't mandate a "low driver IQ" sensor. It would solve a LOT of problems encountered while driving in traffic. (not directed at OP)
You have to start somewhere to get to the middle of nowhere.
2015 YJ Of The Year
Thanks, but my rig is just a Prince among Kings. You folks gave me the answers to build it!
Burlbook48 is offline
post #10 of 12 Old 07-03-2012, 11:31 AM
Xpress
TPS (or TPMS) are a brilliant convenience for those who use their cars as drivers and don't want to have to worry about all of the safety checks that most don't have the time for. Believe it or not people do pay attention to that light when it comes on, and come to fill their tires up. It's on a very short list of government mandated safety devices that I actually advocate for.
Whoever said it works off of tire RPM is only partially correct. The direct system actually employs a pressure sensor inside of the tire that transmits a live feed to the vehicles computer, based off of the actual pressure inside of the tire.
An indirect pressure sensor uses RPM sensors to detect slight variances in angular velocity from an under-inflated tire, sensors not located inside of the tire. The vast majority of vehicles out there today employ a direct system, the indirect system is fading away.
If the light is still on there may be a few things at play:
1. Your tires are actually under-inflated.
2. Your pressure sensors are not set for the tires pressure (I.E. from bigger tires that run a lower pressure- it takes 3PSI difference to trip the sensor).
3. Faulty pressure sensing system, in which case the light would actually blink.
4. You need to manually reset the tire pressure light VIA button, normally located on the bottom of the dash panel.
All about that unibody life.
Xpress is offline
post #11 of 12 Old 07-03-2012, 11:41 AM
paul84043
Most of the time you need to overinflated your ties by about 5 psi and then back down. I believe they trigger around 32 to 36 psi.
I like the tpms system, it's shown me my last 4 low tires before it ever became an issue. If you don't like it, get a procal or other module and turn it off.
The current jeep system has nothing to do with rpm. It's direct pressure reading.
Make a man a fire and you keep him warm for a day....Set a man on fire and you keep him warm for the rest of his life....
paul84043 is offline
post #12 of 12 Old 02-04-2015, 03:56 PM
MarkB73
I bought a 2015 Wrangler unlimited. Had the dealership install a 3"lift and then added some 20x12.50 Fuels and 35x12.5 open country tires. I had them switch over the sensors. I have taken my jeep in 7 times already over the past 2 months (only had the dam thing 3 months), they have reset sensors, replaced two sets of sensors and the light continues to appear after I drive it for 3-4 days. This last time I picked it up after they had it two days and the light came on 15 minutes after I left the dealership! Now the manager is telling me they want to put regular wheels on it for a week to see if the light comes on. If it doesn't its my wheels and tire set-up, which he then says they will not be able to do anything else about. He said the Chrysler people are telling him that he new sensors don't sit properly on my wheels and therefore create the issue. I told him that wasn't good enough. he mentioned the after market kit to turn of the light, but I told him that would be just what they want so my factory warranty becomes void. anyone else having issues like this? Anyone gone up the chain with Chrysler. I certainly don't think i'm the first person to change to a 3" lift and 35" tires! such bull****. Please help me or advise me on how to handle this situation. This is my first brand new vehicle ever and I already regret it. Thanks Mark.
MarkB73 is offline
