Looking for a reliable Subwoofer. - JeepForum.com
post #1 of 5 Old 09-23-2012, 05:30 PM Thread Starter
PeterSyz
I have an 8 inch Bazooka tube sub in the back of my YJ because that's about all that fits back there without buying an inclosure. Unfortunately my last trip offroad gave it a good beating and now it barely works. I found the enclosure I want to buy and I'm wondering if anyone has found a good subwoofer that can handle the bumps and hits of the wilderness. Let me know! I need one that can take a beating but still put out some good bass.
Instagram: @petes_jeeps and @petersyz
1992 4.0L YJ | Pennsylvania
1998 5.9L ZJ | Kansas
PeterSyz is offline
post #2 of 5 Old 09-25-2012, 10:39 AM
Vwright14
depends on how much you want to spend..enclosure size..amp rating and what kind of output you are looking for.
2012 4Runner T.E.-KDSS,5100,285 Duratracs,1999 Expedition Mild lift/level, 285 Toyo's
Vwright14 is offline
post #3 of 5 Old 09-25-2012, 06:29 PM
frenchy206
True. Whatever solution you choose, the box should somehow held to the floor. The easiest is Velcro on the bottom of the box.
03 TJ Rubicon
frenchy206 is offline
post #4 of 5 Old 09-28-2012, 12:43 PM Thread Starter
PeterSyz
Looking for either a 10 or a 12. I'm looking to spend no more than $500 and it needs to be able to stand the test of offroad bumps.
PeterSyz is offline
post #5 of 5 Old 09-29-2012, 03:31 PM
Vwright14
There's tons of stuff out there...I'm running a couple SKAR audio 8in subs...pretty hefty at 17.8lbs each.....and build the proper braced box and you shouldn't have a problem.
audio , bass , sub inclosure , sub replacement , subwoofer
which is more reliable? wannafixmyjeep YJ Wrangler Technical Forum 9 12-21-2011 09:18 AM
Aftermarket Subwoofer in Factory Subwoofer box anyone? SpikesterUK JK Wrangler Technical Forum 2 11-20-2010 04:56 PM
The TJ reliable? MasterCujo TJ Wrangler Technical Forum 74 05-15-2010 11:01 PM
Which is more reliable, '04-'05 JGC or '02-'04 TJ? jmwilson Wrangler General Discussion 11 02-12-2010 12:26 AM
Are TJ's Reliable? xkuzme1 TJ Wrangler Technical Forum 17 09-24-2009 08:06 AM
