Looking for input and interest in a gauge face kit - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > Wrangler General Discussion > Looking for input and interest in a gauge face kit
Tactical Recovery Equipment Soft Shackles!!!50% Off Sale at KrawlOff-Road.com50" LED CREE Light Bar Pair With Wiring Kit
Unread 09-30-2013, 09:18 AM   #16
Azzy
Azzy's Avatar
Originally Posted by LimeLJ View Post
In this order, left to right in the top left:
Fog Lights, Fog Light Symbol(Green)
Cruise, Text "CRUISE"(Green)
Sentry Key Immobilizer, Key with Forbidden circle over it Symbol(Amber)
In this order, left to right in the top right:
Front Locker, Text "FRONT LOCK"
Rear Locker, Text "REAR LOCK"
Four Wheel Drive, Text "4WD"(Amber)
Directly below the Four Wheel Drive indicator:
Shift Up, Up Arrow Symbol(Amber)
I refurbish and reprogram Jeep gauge clusters. If you have any questions I can probably answer them.
I may have some business for you... look for a PM later today
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline   Reply With Quote Quick reply to this message
Unread 10-15-2013, 09:09 PM   #17
Azzy
Azzy's Avatar
Here is the 03+ TJ cluster, custom requested by a client. in progress, but getting close to a V3.
http://picasaweb.google.com/11452670...eat=directlink
Unread 10-15-2013, 09:26 PM   #18
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
*** Cough YJ's need some love Cough ****
87-91 the light shines around the gauges face and they have a clock
92-95 Gauges are back lit and a 4wd light replaced the clock
'89 YJ The Smurf Build Thread
'99 XJ Black Betty Build Thread
Tom95YJ is offline   Reply With Quote Quick reply to this message
Unread 10-16-2013, 09:09 AM   #19
Azzy
Azzy's Avatar
I have a set of guages sitting at the house for a YJ. Problem is, the backlit portion is also the main structure. So you have to blot out behind, and still get light up front. To do it right.
Im noodling those, have a set from Simpson Jeep salvage on loan to try and get it working.
My main push right now is to get the JK ones up and going, because that is where my requests are. Looking into some expensive printers that will allow me to do all of them, so its a matter of growing.
Unread 10-17-2013, 08:34 AM   #20
Lastshot
The TJ Type ones with the carbon fiber background look awesome, When I go to do the LED mods I'm going to pick one up for sure! (matching Heater control bezel is great too!)
{Project "New Start" -'05 LJ build }~{SOLD '98 TJ -"Blue Steel"}
{You know you drive a TJ when....}
gily25 Says...
Issues only become problems when you don't have the tools or time to fix it.
Mike318 Says...
I like my 4.0L like I like my ****... stroked and blown. :duhrock:
Lastshot is offline   Reply With Quote Quick reply to this message
Unread 10-17-2013, 08:44 AM   #21
Azzy
Azzy's Avatar
Thank you! Although I would REALLY think about converting to LEDs. There are a lot of cons, and very few pros. unless you are converting to jeep to an EV, and need every bit of amperage possible, stick to regular bulbs. They will live longer and look better. The later TJ clusters were engineered with LEDs and cooling in mind, and probably run on much lower voltage (aka voltage regulation is handled elsewhere in the cluster) .
Unread 10-17-2013, 10:37 AM   #22
bogleparsons
Are you saying LED's don't last as long as incandescent bulbs?
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline   Reply With Quote Quick reply to this message
Unread 10-17-2013, 11:16 AM   #23
Azzy
Azzy's Avatar
In the application, no. they dont. On paper, in happy internet land, where they dont have fluctuating temperatures, vibration, and wildly varying voltage... they work 100%
Unfortunately, the things that kill LEDs are heat and voltage. Our power systems vary from 9v to 14v. Too much, burns tehm out. Too little (over teh course of time... say 6 months) kills them. Turn your interior light dimmer bulb, and you are killing them at an even better pace.
They expect a stable voltage, cooling (or proper heatsink) to function right. Our vehicles were meant with incandescent bulbs in mind. The ones in my 96 are original. Teh ones in my 1980 Honda are original. They last. The LEDs I tried replacing them with... lasted 2 months.
Except for the turn signal leds... those lasted longer, as well as the brake light ones. Probably because they have an easier time cooling and have a set voltage.
Unread 10-17-2013, 11:18 AM   #24
Azzy
Azzy's Avatar
That being said, companies do make a proper replacement bulb, that has teh right socket for the gauges, built in heatsink, and more than just a resistor wired in tho drop the voltage.
They also cost about $10 a piece before shipping.
Unread 10-21-2013, 12:29 AM   #25
YJjeeper1
Definitely interested in a yj kit.. Shouldn't be too much work right? It's just circles lol
YJjeeper1 is offline   Reply With Quote Quick reply to this message
Unread 10-21-2013, 10:23 AM   #26
Azzy
Azzy's Avatar
Well I got the small ones figures out, they are the same as used in the older XJs. The other ones are just translucent 1/8" thick circles that hold the electronics up.
Unread 10-22-2013, 11:15 AM   #27
YJjeeper1
Well they look great, can't wait for the yj design
Unread 10-22-2013, 05:19 PM   #28
Lastshot
Do you still need a picture of an 05' LJ dash Lit up during start up? I've got access to a camera finally if you still need it
gily25 Says...
Mike318 Says...
Unread 10-22-2013, 07:12 PM   #29
Azzy
Azzy's Avatar
I would not complain, especially if you can catch it in diagnostic mode (hold trip reset in while turning to run, release when it starts chiming) with a straight on shot
Unread 10-23-2013, 09:05 AM   #30
Lastshot
I Tried Diagnostic mode, but it basically just went through each of the lights and gauges individually, so I got this picture instead.
Everything LimeLJ said was correct, Im just gong to add a couple.
*Bottom Left * Low fuel Lamp -> E-Brake Light -> ABS Light
*Bottom Right* Has CEL -> "Check Gauges" -> Airbag Light
*Top Center* -> High beams directly above Seatbelt
gily25 Says...
Mike318 Says...
