Long crank times on 92 2.5L - JeepForum.com
post #1 of 1 Old 08-31-2013, 08:43 AM Thread Starter
Martimus
I need some help please as I am new to the jeep world I have a 92 Wrangler with the 2.5L.
The problem is it will start great first thing in the morning but after that if you shut it of and it sits for more than 2 min. it take a very long time of turning over before it will crank.
Here is a list of what I have done to resolve this so far and I might add it would hardly run at all before this and it would take 45-60 sec. to start when I began.
Replaced: Battery, TPS, crank sensore, fuel pump, fuel filter, fuel pressure regulator, Distributor, cap and rotor, plugs, valve cover gasket( it was leaking)
Did oil change and I only run non ethanol gas.
please help going nuts over this.
Oh ya and the rpms take a bit to drop when you come up to a stop sighn?????
Martimus
Martimus is offline
