LJ Unlimited v. LJ Rubicon Unlimited - JeepForum.com
post #1 of 22 Old 12-23-2011, 10:55 PM Thread Starter
Yucca-man
So for those of you who have seen my Rubi-clone rant thread (http://www.jeepforum.com/forum/f176/...lones-1303982/ ), I came to a realization - other than lockers in the front and rear 44s and the NP241OR t-case, is there really much advantage to the Rubicon? More importantly, is there enough to account for the $2,000 and more most buyers are asking for simply because of the "Rubicon" badging?
Not a Rubicon...which is okay considering how much chrome would have to be removed
Yes, I've read http://www.jeepforum.com/forum/f9/st...1/#post4118327
Selectable lockers front and rear - advantage Rubi.
D44 rear - Both have rear D44s, the LJ with a limited slip. Tie.
D44 front - not sure it's an advantage, as it shares multiple parts with the LP D30 anyhow. A high-pinion D30 out of a late-model XJ will be very similar strengthwise, with the added advantage of somewhere around an inch of ground clearance. Consider the fact that I have a '96 XJ (with the high-pinion D30 and larger u-joints) that I might not sell when I buy the LJ, and the low-pinion D44 really isn't as attractive. Advantage LJ.
T-case. This is the one point in which the LJ Rubi has the advantage, simply because 4:1 reduction beats 2.72:1 - without having to install anything. Advantage Rubi.
So what else am I missing that really stands out with the LJ Rubi over the LJ? Anything? Or am I better off to expand my search parameters to include all '05-06 LJs? I'm still strongly in favor of the 6-speed so '04 isn't really an option.
Yucca-man is offline
post #2 of 22 Old 12-23-2011, 11:27 PM
Brainwashed2566
You forgot all the really important stuff like hood stickers and fender flares and stuff.
2005 White LJ Mild Build = Fun Rig
2003 Ram 1500 5.9 Mag = DD
1997 Green XJ Bone Stock = SOLD
Brainwashed2566 is offline
post #3 of 22 Old 12-24-2011, 01:45 AM
1222
RIP John
1222's Avatar
There is more to the Rubicon than what you mentioned and no, I’m not going to list them. That kind of debate has been beat to death over the years since the Rubi was first introduced. Perhaps others will chime in and list what else the Rubies come with or you can listen to people like Brainwashed2566 and be brainwashed yourself with dumb statements like his.
1222 is offline
post #4 of 22 Old 12-24-2011, 07:01 AM
dreed
Very stupid.
Keep the XJ.
dreed is offline
post #5 of 22 Old 12-24-2011, 07:49 AM
commodore_dude
commodore_dude's Avatar
The D44 rear is not a tie. Regular LJ has a clutch LSD which will need to be rebuilt every 50-100k miles. Rubi has a gear LSD which will not. I'm supremely happy with my Rubi, but if your build plans include say D60s, an Atlas transfer case and ARB lockers, there'd be no reason for you to get one. My plans don't require any of that, so it was perfect for me.
2006 Rubicon Unlimited
1998 Buick LeSabre Custom
commodore_dude is offline
post #6 of 22 Old 12-24-2011, 08:13 AM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
Why, you can make more money selling idiots your rubi parts than a LP30 and 231.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #7 of 22 Old 12-24-2011, 08:38 AM
LJameson
Also the D44 front allows you to gear lower then 4.88.
1990 YJ
LJameson is offline
post #8 of 22 Old 12-24-2011, 08:41 AM
scubamc
That extra $2000 is cheap compared to what it would cost to turn a regular LJ into a Rubi.
Lockers $1600+
Gears and install kits $500+
4:1 kit $1100+
Labor $2000+
Plus with the 44s you can gear lower than 4.88.
Horsepower is like a hot girl with STDs. You know you want to hit it but you're afraid of the consequences.
scubamc is offline
post #9 of 22 Old 12-24-2011, 01:42 PM Thread Starter
Yucca-man
Fair enough, I realized I didn't lay out my plans. I'm looking at going about 3" lift with 33x10.50s.
For that, 44s or an HP30 and a rear 44 will be perfect. Even with the 4.10s in the Rubi, that tire selection may still call for a regear, so the savings on a regear isn't there.
Dunno...just thinking "out loud" here and trying to decide which direction I'm headed. And no, keeping the 16-year old XJ isn't going to happen.
post #10 of 22 Old 12-24-2011, 01:47 PM
commodore_dude
Your plans are about the same as mine (1" BL/MML, 2.5" lift, 33s). So the axles, lockers and transfer case are all probably things you'd keep, and that's well worth $2,000. With the 6-speed you'd be looking at regearing to 4.56 most likely rather than 4.88 like us auto folks have to.
post #11 of 22 Old 12-24-2011, 02:01 PM Thread Starter
Yucca-man
4.88 auto or 4.56 6-speed on 33s? That's the thing I haven't quite pinned down. I know on the XJ with the AW-4 auto, 4.56 is an excellent match for 33s. Wasn't sure about the 6-speed though, despite dozens of threads giving ranges anywhere from about 4.10 to 4.88 or higher...
post #12 of 22 Old 12-24-2011, 02:26 PM
MayRoll
The NSG370 is a pretty forgiving transmission. The 4.10's in the Rubi are a resonably good match for 33's. I wouldn't spend the money regearing a Rubi for 33's with the 6-speed. Gearing to 4.56 is a better match for 35" rubber.
First of the Breed
03 Khaki Rubi
JF short arm champ
MayRoll is offline
post #13 of 22 Old 12-24-2011, 02:33 PM
KKiowaTJ
To each his own, But to me the Tcase and the 5.13 gear option is enough for me to buy a rubi vs a cobble clone. If your going to build toward it, Why not start out with the vast majority of the expensive parts and fine tune the rest. Good luck either way
MOPAR!
KKiowaTJ is offline
post #14 of 22 Old 12-24-2011, 05:16 PM
jeepinmichguy_
Soar Forever Six
My wifes TJ is geared to 4.56 with 33's and the NSG-370. I would say while it is a nice peppy combo and feels great offroad 4.10's actually would have been a better combo with as much street driving as she does. She barely uses 1st gear on the road.
ΜΟΛΩΝ ΛΑΒΕ
post #15 of 22 Old 12-25-2011, 08:16 AM
Zeep
I never use 1st gear on road, and I have the stock 31 inch rubber!
JEEP THE AR-15 OF THE AUTOMOTIVE WORLD
Zeep is offline
Unlimited vs Unlimited Rubicon JKRubicon90 JK Wrangler Technical Forum 19 02-27-2011 09:59 PM
Short arm lift for 2005 Unlimited Rubicon ....OME or Rubicon Express which manufactur Rubi Unlimited TJ Wrangler Technical Forum 6 02-20-2011 07:08 PM
Unlimited Rubicon or Sport Unlimited? Superstar TJ Wrangler Technical Forum 36 02-23-2010 03:21 PM
Buy a Unlimited Rubicon? Build a Unlimited X Monster? Piet JK Wrangler Technical Forum 21 05-09-2008 03:18 PM
Better performance offroad- jk rubicon vs. 4 door unlimited rubicon David Hinton JK Wrangler Technical Forum 6 07-20-2006 10:07 AM
