lifting - Page 2 - JeepForum.com
post #16 of 27 Old 10-16-2013, 12:24 PM
dadkinsemt
Go to the TJ technical forum and read through the FAQ. There are lots of links and great write ups on how to do it.
Body lift is cheep and can fit bigger tires. Usually $100 to 200. Makes room to push the t-case up so you have better ground clearance in the middle of the jeep.
Dusty
05 LJ rubicon
dadkinsemt is offline
post #17 of 27 Old 10-16-2013, 12:42 PM Thread Starter
centexryan
What about the front and rear of the two jeep? Nothing you can really do? And how much and how easy is a 1.25 or a 2 inch body lift. Yall said 1.25 so is it easy like I can do it at my house?
centexryan is offline
post #18 of 27 Old 10-16-2013, 12:52 PM
dadkinsemt
As for front and rear of the jeep, well you can get different bumper or cut the ends off. Make them stubby bumpers. If you are hitting your axel on things, try a different line.
And yes you can do a body lift at your house. Floor jack, blocks of wood, and hand tools. Videos all over you tube on how to do it.
Dusty
05 LJ rubicon
post #19 of 27 Old 10-16-2013, 12:56 PM
Ironhead
what about the front and rear?
body lifts are pretty straight forward and require minimal tools. a 1" mml usually goes hand in hand with a bl. stay at 1"-1.25"
Ironhead is offline
post #20 of 27 Old 10-16-2013, 01:09 PM Thread Starter
centexryan
Yes I was talking about axels there isnt a way to make them higher? Ok and I wont need wheel spacers if I buy 33 inch tires or do I? All depends on the width if the tire im assuming
post #21 of 27 Old 10-16-2013, 01:13 PM
Ironhead
sure, you can go with portals
in all seriousness, the only way to get the axles higher is to run some bigger meats
are you on stock rims? even a 33x10.5 could rub with stock backspacing
Ironhead is offline
post #22 of 27 Old 10-16-2013, 01:15 PM Thread Starter
centexryan
Not stock they are motometals but im not sure the size they were on when I bought the jeep I'll post a picture of them
post #23 of 27 Old 10-16-2013, 01:35 PM
LeeMasterGT
Also a little light reading for you: http://www.jeepforum.com/forum/f9/so...y-tuck-942018/
That helped me when I was first starting out.
Build
LeeMasterGT is offline
post #24 of 27 Old 10-16-2013, 01:39 PM Thread Starter
centexryan
I have to edit the photo and im at work right now I will post as soon as I ger off thank you veey much for all the knowledge and information
post #25 of 27 Old 10-16-2013, 01:56 PM
dadkinsemt
Also this link. The above link is in here.
http://www.jeepforum.com/forum/f9/tj-forum-faq-615132/
Dusty
05 LJ rubicon
post #26 of 27 Old 10-16-2013, 01:58 PM
dadkinsemt
Originally Posted by Ironhead View Post
sure, you can go with portals :thumbsup
Dusty
05 LJ rubicon
post #27 of 27 Old 10-21-2013, 10:27 AM
WoodTwister
interesting
Keeping a tab on this one..
WoodTwister is offline
