lifting - JeepForum.com
post #1 of 27 Old 10-16-2013, 11:10 AM Thread Starter
centexryan
lifting
I have a 2005 jeep wrangler unlimited. Its got a 2.5 inch lift already but I want it higher. If I buy 2 inch coil spring spacers will I have to buy anything else or can I buy the spacers and put them on as the jeep stands?
centexryan is offline
post #2 of 27 Old 10-16-2013, 11:16 AM
LeeMasterGT
Are you going to remove the old 2.5 inch lift? Or are you wanting a total of 4.5 inches of lift? If that's the case you'll need a lot more... Changes to your driveline angle mean an SYE and CV driveshaft, adjustable control arms to change pinion, new shocks, longer brakelines, new track bars, possibly new track bar brackets. I'm sure I'm forgetting things.
If you're looking at just swapping out the old 2.5 inch lift for a 2 inch you'll be just fine. If you're looking to add 2 inches... There's going to be a significant investment.
Here's another thread that is already going to give you an idea: http://www.jeepforum.com/forum/f9/su...-kits-1670113/
Build
LeeMasterGT is offline
post #3 of 27 Old 10-16-2013, 11:19 AM
Ironhead
yes, and do not do that.
if you really want to, then you would have to do everything that goes with a 4.5" lift. control arms, sye, cv driveshaft, new shocks, front and rear track bars, etc, etc
if you are going to go through all of that, why not get 4" or 4.5" springs
what is your goal for the jeep, type of wheeling, max tire size, and budget?
Ironhead is offline
post #4 of 27 Old 10-16-2013, 11:22 AM Thread Starter
centexryan
Well I'd like to have a 4.5" lift so I can put like some 37" bfg at's or trail grapplers and also 1.5 inch wheel spacers so the tires will fit
post #5 of 27 Old 10-16-2013, 11:23 AM Thread Starter
centexryan
Budget is fairly limited pay check to pay check kinda thing
post #6 of 27 Old 10-16-2013, 11:26 AM
Ironhead
you need to do a lot more than just adding a bb to run 37's, and it isnt budget friendly
if you have a d44 in the rear, thats a good bonus. if its a d35, its axle swap time
stock brakes, steering, axle shafts, wheelbase, ujoints, and several other things are not ideal for 37's
can it be done, yes, will it be safe and reliable, no
Ironhead is offline
post #7 of 27 Old 10-16-2013, 11:31 AM Thread Starter
centexryan
Ok so if I just lift it 4.5 inches and leave the tires that are on it "31.5" will it be reliable? I dont want to lift it anymore if it wont be reliable
post #8 of 27 Old 10-16-2013, 11:34 AM
Ironhead
that depends if you are using quality parts or not. to do a 4" or higher lift, you'll need a sye and cv driveshaft, new control arms, and front and rear track bars, longer sway bar links, longer brake lines, new shocks, etc
just throwing some pucks on top of the springs isnt going to do it
Ironhead is offline
post #9 of 27 Old 10-16-2013, 11:40 AM Thread Starter
centexryan
Ok so what would you recommend? What type of lift? It currently has an oldman emu but that wont matter if I need to buy new everything
post #10 of 27 Old 10-16-2013, 11:45 AM
Ironhead
why? whats wrong with your current lift? what are you trying to accomplish? budget? what are of the country do you live in? how often do you get off the pavement?
Ironhead is offline
post #11 of 27 Old 10-16-2013, 11:52 AM Thread Starter
centexryan
Well I get off pavement everychance I get rock crawl, mudding, trails, creeks etc. Nothing is wrong with it I would just like it taller. Im an avid adventurer I love being outside and my jeep takes me where ever just want it a little taller
post #12 of 27 Old 10-16-2013, 11:54 AM
dadkinsemt
OME is a high quality lift. Honestly, don't think you should mess with it. Look at doing some body lift and belly up. You will clear 33's and be a very capable vehicle. Look at Unlimited04 build. He runs that lift and belly up and is one of the best vehicles I've ever seen. Looking to do something like that to my LJ.
37's is a money pit of a jeep. On a budget, 37's is not recommended.
Dusty
05 LJ rubicon
dadkinsemt is offline
post #13 of 27 Old 10-16-2013, 11:55 AM
Ironhead
so whats holding you back as of now?
id imagine its your diffs and skid.
you could do a 1.25" body lift and throw some 33's on it. you could also look into a tummy tuck, but that requires more work. its not necessarily getting the top of the jeep up higher, its getting the bottom of the jeep higher that is truly important
Ironhead is offline
post #14 of 27 Old 10-16-2013, 11:58 AM
dadkinsemt
Seems like ironhead and I agree.
Dusty
05 LJ rubicon
post #15 of 27 Old 10-16-2013, 12:03 PM Thread Starter
centexryan
Man you guy's are extremely helpful. A 1.25" body lift how and cost? Also what is a tummy tuck im a new jeep owner had it for almost 6 months so I guess not to new. But what is a tummy tuck?
